sometimes the timer knob moves and dryer shuts off normally and sometimes the time doesn't move at all and runs until manually shutting off. Will a new timer resolve this problem or could it be something else?
Whats the model# of your dryer smonski? Its located inside the dryer door or on the top console.
Does this happen on auto-dry or timed-dry? Jake
It happens both on auto and timed dry. Thank you for your help. |
Yes, then its likely your timer thats bad.
Here's the cheapest timer I found for your model: Manufacturer's Number: 3976581 Jake
Nope, never buy used parts, thats a big NO-NO in the appliance business.
To install it, just remove the end cap console screws#8 then the console will slide forward and lift up, then take off the console back access panel#1. Take off the knob#20, then make down where all the wires connect to on the old timer, and re-connect them the same on the new timer. Remove the timer mounting screws#9 and put in the new timer. Make sure you unplug your dryer before doing any of this! ![]() Jake
buyinit (July 11th, 2008) | ||
Jake, I replaced the timer and it is working on timed dry. My wife's only remarks are that the timer is louder (???) and that the sensor dry is not working. I think at one point we had a ventilation issue when the dryer was pushed against the wall but that has been cleared up.
Glad its working again on timed dry.
If auto-dry isn't working its likely the electronic control board is bad as well, don't know how much you want to spend on it, its about $112: Manufacturer's Number: 8558178 But you use on timed forever if you don't want to put any more money into it, and it will still work fine. Jake
buyinit (July 12th, 2008) | ||
on auto-dry it shuts off but the clothes are still damp. could it be something else?
also found this part used delivered for less than $10 if that is the problem. Gotta be worth a try with 90 warranty and free returns??
| Erratic Dryer Behavior (MDE5500AYW) | Lawrence | Maytag/Magic Chef/Admiral/Jenn-Air | 9 | February 12th, 2007 04:20 PM |
| GE Electric Dryer runs but no heat | vdrsolo | GE/Hotpoint | 1 | September 27th, 2006 12:44 PM |
| New Dryer keeps tripping circuit breaker | wabeeth | Sears Kenmore | 2 | February 14th, 2006 07:40 PM |
| Whirlpool Dryer gets Warm not Hot, Takes long to Dry | jnicosia | Whirlpool/KitchenAid | 4 | August 19th, 2005 08:48 PM |
| Kenmore 90 Series Gas Dryer Problem | HomeRepairGreenhorn | Sears Kenmore | 9 | March 15th, 2005 01:02 PM |
