Old July 4th, 2008, 02:30 PM
mickey_bigdaddy is on a distinguished road
Default Whirlpool Calypso Dryer (GEW9868KQ0)
I have a Whirlpool Calypso Dryer (GEW9868KQ0) and it has been working great until yesterday.
It will not heat now. I cleaned all the lint out of it and my vent. Nothing but cold air comes out. I opened up the heating element door and the element isn't getting hot. Nothing but cold air coming out of the back vent. The heating element looks good. I don't see any burns or open wires. Is the heating element bad or could there be something else wrong with the dryer? How do I troubleshoot this problem?
Thanks.
Old July 4th, 2008, 03:44 PM
You can get a cheap volt/ohm meter at Radio Shack.
If your dryer is getting 220/240 volts and just runs and no heat, then its either your thermal cut-off or element thats bad.
This link will guide you to how to take it apart to access your thermal cut-off thermostat on the heater housing and heater itself:
http://www.applianceaid.com/whirlpool-dryers.html#four
You would need an ohm meter to test continuity on your thermal cut-off#47 here:
Also ohm your heating element for continuity too.
Unplug your dryer first before doing this!
Here's another help link:
http://www.applianceaid.com/whirlpoo....html#no-eheat
Here's the thermal cut-off#47 for your model:
Manufacturer's Number: 279769
279769
Here's the heating element#14:
Manufacturer's Number: 3387747
3387747
Whirlpool dryer LER 7646 AN1 stops in middle of dry auto cycle imidazol97 Whirlpool/KitchenAid 1 January 31st, 2008 10:07 AM
Dryer stops with Auto-High Setting on Whirlpool scottB_44 Whirlpool/KitchenAid 5 October 18th, 2007 12:55 PM
Whirlpool Duet Dryer Repair story -- stacked in a tight spot curiojj Appliance Stores & Service Complaints - East of the Mississippi 0 June 23rd, 2007 02:18 PM
Whirlpool Duet Dryer Repair story -- stacked in a tight spot curiojj Whirlpool/KitchenAid 0 June 23rd, 2007 02:18 PM
Whirlpool Dryer gets Warm not Hot, Takes long to Dry jnicosia Whirlpool/KitchenAid 4 August 19th, 2005 08:48 PM
