Old October 6th, 2008, 09:39 AM
boriquaracer is on a distinguished road
Default whirlpool dryer won't dry.
i have a whirlpool dryer thats 1 year old. last night it stopped drying. i replaced the thermal fuse today and it is still not drying . what can i check before buying parts. i have a multimeter available, i just need to know where to look. it spins fine but i'm nopt sure if the timer is working either. i set it to 30 min and it basically stays there. i'm at a loss. please help!!!
model#wed5100sq0
Old October 6th, 2008, 11:06 AM
I would ohm your thermal cut-off for continuity. Take the wires off of it. Unplug your dryer first!
Its #6 on the top side of your heater housing here:
Manufacturer part number 279816 is RepairClinic item number 2651
Old October 6th, 2008, 04:27 PM
i took the wires off and the measurement was between 2 and 3 ohms. is there supposed to be infinate ohms between the 2 connectors?
Old October 6th, 2008, 05:49 PM
No, infinite ohms would mean NO continuity.
So with 2-3 ohms thats fine. You can also just jump the wires to see if it starts heating.
Also use your volt meter to test for how much voltage you have at your heating element when its running, you should have 240 volts.
Old October 6th, 2008, 06:30 PM
would there be a need to jump the wires if the reading is ok? i'll check the voltage tomorrow after i get home from work. thanks for your help.
Old October 6th, 2008, 09:55 PM
No, its just another way to confirm if the thermal cut-off is good or bad.
Ok, sounds good.
Old October 7th, 2008, 10:31 AM
ok i think i checked the heating element. i placed one of the probes on one of the red wires and the other on the the red wire with a line and i got no voltage. i placed a probe on the red wire and grounded it to the metal on the back of the dryer and got 118v. what am i doing wrong????? i also checked between the red and orange wires and got nothing. let me know where to go from here. thanks
Old October 7th, 2008, 10:55 AM
Sounds like possibly a voltage issue in your home breaker box, check for 240 volts were your dryer cord connects to your dryer's therminal block in back of your dryer. Put your volt meter leads on both ends of the terminal block, should read 240 volts.
Remember Black & Red on the ends are HOT, White in the middle is NEUTRAL
Then put one of your meter leads in the middle of your terminal block and one on the end you should read 120 volts, then on the other end you should read 120 volts as well.
Old October 7th, 2008, 04:17 PM
i did just that. the right side measures 118v. the other 3v. i guess i should replace the wire from the box all way to the dryer. would it be wise to tap off another line to supply the other 120v? well thanks for all of your help.
Old October 7th, 2008, 07:01 PM
No,
Don't do that. Is the dryer power from your home breaker box or fuse box in your house?
Unless your an electrician, I wouldn't take a chance to try to rewire it, 240 volts is a way different animal than 120 volts.
To be on the safe side, I'd contact a licensed electrician to fix the voltage problem to your dryers outlet in the wall.
Kenmore Dryer 417.94072301 No Heat brimmyhop Sears Kenmore 1 September 29th, 2008 12:46 AM
Whirlpool dryer LER 7646 AN1 stops in middle of dry auto cycle imidazol97 Whirlpool/KitchenAid 1 January 31st, 2008 12:07 PM
Dryer stops with Auto-High Setting on Whirlpool scottB_44 Whirlpool/KitchenAid 5 October 18th, 2007 02:55 PM
Kenmore dryer takes hours to dry cloths fritcr Sears Kenmore 13 September 1st, 2005 09:17 AM
Whirlpool Dryer gets Warm not Hot, Takes long to Dry jnicosia Whirlpool/KitchenAid 4 August 19th, 2005 10:48 PM
