Old October 19th, 2008, 06:44 AM
js1268 is on a distinguished road
Default Whirlpool making screeching/whining noises!
Hey folks,
Well, I decided to get into trying to figure out what the problem was.
Initially, the loud high pitched squeeling only occurred on the spin cycle- at times not spinning at all, and sometimes very slowly taking a while to get to full velocity- clothes ultimately spun out, fine.
I let it go until I mustered up the courage to do the job. By then, it was making the sound even during agitation (more of a whining sound, then).
At first, I figured it to be either the motor couplings or the agitator dogs- so I took those things apart and they're absolutely fine.
Next, I took the gearbox out because I noticed that when I moved the washer, the ground was a little damp from oil...not a tremendous amount, but it was there- looked like some had even splattered up into the plastic bin as well.
Anyway, I took the gear box apart and everything is operating just fine- no worn gears at all and nothing binding up
Any ideas?
I'm looking at the clutch assembly and the brake/drive tube- but i'll be damned if I know what to look for that would indicate these parts are at fault.
Drive block is fine as well.
Any help would be greatly appreciated!
Paul
Old October 19th, 2008, 07:07 AM
Incidentally, I decided to take the pump off upon the suggestion from someone on another forum.
I found one of those white dental flossers in the pump.
Could that have been the cause of the problem, all along?
Old October 19th, 2008, 07:55 AM
Hi Paul,
Yes, that white dental flossers could have been making the pump impeller make that noise.
Whats the model# of your washer? Its located inside the lid/door.
Once you removed the dental flosser did it sound normal again?
Old October 19th, 2008, 08:11 AM
Hi Jake,
Well, it's a direct drive Whirlpool LSQ8543JQ0
I haven't completely put everything back together, yet.... I had pulled apart the gearcase to inspect everything, and in doing so drained the oil.
I'm gonna head to a local Autozone and pick up some 90 weight Lucas oil and some red RTV
I'm also guessing that in addition to any impeller sound that the motor wasn't able to turn the gearcase as it should have?
I mean, everything else looks fine, literally. Any ideas on what else I should look for, as I have everything out?
....I was thinking about replacing the brake/drive tube assembly and clutch just for the hell of it.... No?
Old October 19th, 2008, 08:17 AM
Yes Paul, From the repairs I do on these models I find if the gearcase is ok, then its the basket drive and clutch assembly thats wearing out causing the problem.
Here is the basket drive for your model, you can order:
Manufacturer part number 285792 is RepairClinic item number 1254
285792
Here is your clutch assembly:
Manufacturer part number 285785 is RepairClinic item number 2670
285785
Old October 19th, 2008, 08:34 AM
Excellent!
Thanks, man. I hate to think I pulled this machine apart in vain.
Will post results once back together.
Old October 19th, 2008, 08:49 AM
Ok, sounds good Paul.
Old October 22nd, 2008, 03:38 PM
The parts arrived today, and when I opened them I immediately noticed a difference between 2 things in particular...
The shaft on the drive basket/tube did NOT have a series of grooves on it that the one I pulled out had in it- I thought these were normal...they obviously were not.
Also, the cam on the bottom of the used one was obviously very worn, as the new one was much thicker at the ends of the arms.
Everything looked okay with the clutch.
Anyway, I put everything back together and, voila!... It's like a new washing machine
Thanks for the help, Jake!
...Now it's off to fix the dryer that's squeeling and scraping- replacing idler pulley, belt, and rollers... =-)
I'll be damned if I buy new large appliances after 8 years... My mother had a washing machine and dryer that lasted nearly 20 years.
Old October 22nd, 2008, 08:20 PM
Sounds good Paul, good job fixing it.
[FIXED] Maytag Dryer Making Awful Screaching Squealing Noises *with video* aefor3 Maytag/Magic Chef/Admiral/Jenn-Air 7 April 3rd, 2009 07:38 AM
whirlpool not making ice d_holden Whirlpool 3 March 10th, 2008 04:21 PM
Ice Maker Will Not Stop Making Ice - Whirlpool Model ED22TEXHW03 AppMon235 Whirlpool 10 September 28th, 2007 11:42 AM
Whirlpool ice-maker keep making ice after ice-bin full ysp Whirlpool 9 December 7th, 2006 04:30 PM
Kenmore 66517829000 making grinding noises sleddog218 Sears Kenmore 5 October 19th, 2006 09:36 PM
