Old November 22nd, 2008, 06:46 PM
poncho1010 is on a distinguished road
Talking Whirlpool Washer Repair
I'm in the process of doing some repairs on our Whirlpool washer. I'm changing the bearings and seals in the tub support. Whirlpool recommends putting Rykon grease (pink) on the seals and bearings to prevent wear to the tube spin shaft and agitator shaft. The only problem is that this grease is very expensive to buy from appliance parts stores,about $25-$50 for 4 ounces.I don't know if 4 ounces is enough and would like to know if there is somewhere else I could buy it and buy a larger amount. Do I have to use this grease or can I use something else that is comparable to this? They also recommend putting a small amount of turbine oil down the shaft after the seals are in. Any help would be greatly appreciated.
Steve
Old November 22nd, 2008, 11:29 PM
Hi Steve,
Whats the model# of your washer? Its located inside the door/lid.
Old November 23rd, 2008, 03:28 AM
The model of the Whirlpool washer is LSP9355AW0
Steve
Old November 23rd, 2008, 08:37 AM
Thanks Steve,
What parts are you replacing from this parts diagram of your tub support:
To tell you the truth, I've never had to change any of these parts execept for the #18 suspension pads - Manufacturer's Number: 285744
So I'm not quite sure about what grease to tell you to get, you can go to your local appliance parts store and ask them, they should know.
Old November 23rd, 2008, 09:08 AM
Everything you see in #24. There are 2 bearings and 5 seals. I have to replace the brake and drive tube because it is grooved very bad where the seals and bearings are. I guess that is why Whirlpool recommends putting grease on them.
Steve
Old November 23rd, 2008, 06:09 PM
Ok Steve,
I've never changed the parts in #24 before, I've always changed the basket drive tube/brake assembly and never had a problem.
Here's the basket drive tube/brake assembly for your model:
Manufacturer's Number: 285792
icon
icon
icon285792
Here's the parts in #24:
Manufacturer's Number: 285203
icon
icon
icon285203
Whirlpool Washer Spins Violently. . . Eclectic Lady Whirlpool/KitchenAid 5 March 11th, 2008 09:23 AM
Whirlpool Ultimate Care II washer - no drain or spin emmittbarks Whirlpool/KitchenAid 3 January 19th, 2008 08:44 PM
Whirlpool Duet Washer - Water leak issue soundjunkie Whirlpool/KitchenAid 9 January 19th, 2007 06:41 AM
Whirlpool Washer Runs but won't spin Bus Driver Whirlpool/KitchenAid 7 August 20th, 2006 12:51 PM
Whirlpool Washer not Spinning limetwist Whirlpool/KitchenAid 22 May 17th, 2006 03:30 PM
