Old December 7th, 2008, 11:58 AM
CDL CDL is offline
CDL is on a distinguished road
Default Whirlpool LSQ9200LQ3
Hi Jake: We have a Whirlpool LSQ9200LQ3 washing machine. It is about 5 years old. Notes from my wife...
"The problem began when the washer not spinning at the spin-cycle. You could hear that the washer was on but the tub would not spin.
I first dealt with the problem by shaking the entire machine back and forth until something would catch and it would start spinning. Then I rigged so it will stay on with the top door open and I reach my hand in and spin the tub manually.
Now it will only work if I over load it with towels all the way to the top during the rinse cycle because it will only spin if it has a heavy load in it (I still have to do it manually)."
Some reading I've done suggests it may be a problem with the "transmission?" I did not realize washing machines had transmissions...
Any ideas? As always, thanks Jake!
Chad
Old December 7th, 2008, 09:38 PM
Hi Chad,
Here's the gearcase for your model:
Gearcase for direct drive washer(The manufacturer has replaced part number 3360630 with this item, part number 3360629.)
Here is the basket drive for your model:
Manufacturer part number 285792 is RepairClinic item number 1254
285792
Here is your clutch assembly:
Manufacturer part number 285785 is RepairClinic item number 2670
285785
Here's a good help link to access these parts:
Whirlpool, Kenmore, Roper, Estate, Kitchen Aid: Direct Drive Spin Tube
Here's a similar thread to yours that the member found it was the clutch:
[FIXED] Kenmore 110.22872100 won't spin without help
Old December 14th, 2008, 01:02 PM
CDL CDL is offline
Smile
Hi Jake: As always, I appreciate your help. You are correct that the parts are fairly expensive and I think the repair may be beyond my skill level. I'll consider both the repair and a replacement.
THANKS Jake!
CDL
Old December 14th, 2008, 07:15 PM
Ok, sounds good CDL, thanks for the update.
Whirlpool Duet is a Nightmare! CheerMom Whirlpool Brands Forum 2 November 3rd, 2008 09:45 AM
Whirlpool du1148xtpqa dishwasher sensing won't work dmello1284 Whirlpool 21 August 22nd, 2007 09:49 AM
Whirlpool WED9400S Drum Light nanook Whirlpool/KitchenAid 0 July 28th, 2007 05:55 PM
Done with Whirlpool & Kenmore Beyond Lemons automan1223 Sears Kenmore Brand Forum 0 March 3rd, 2007 10:57 AM
Kitchenaid vs Whirlpool? rv8 KitchenAid 1 January 25th, 2006 11:22 PM
