Old December 20th, 2008, 08:22 AM
bmadsen is on a distinguished road
Default whirlpool duet sport doesnt wrk
I have had my duet sport now just over a yr now oct 2007,
mod #wfw8300sw02
ser # hlu2824939
type #831
It was working fine yesterday then this morning i went to put a load into it i pushed the start button and it spins half a turn then i think it try's to pump water but it won't it just makes an awful noise. the noise comes from the front up-left corner right below where you put the detergent in... any ideas??? i think its the water pump but have no idea... and how long are the warranties on these???
Old December 20th, 2008, 01:47 PM
Sounds like possibly something stuck/jammed in your drain pump.
Here is the official online repair manual for the Whirlpool Duet Sport:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
Read page 4-17 & 4-18 to access the drain pump.
Manufacturer part number W10130913 is RepairClinic item number 1373005
W10130913
bmadsen (December 20th, 2008)
Old December 20th, 2008, 07:21 PM
hey Jake, so I emptied the drain pump and got out a few minor things, still not working. i tried to start another load and and it does the one spin then normally this is when water is suppose to be entering but nothing... and its making that sound by the detergent dispenser motor and assembly its almost like there is a little lid that's being opened and closed very fast
Old December 20th, 2008, 07:23 PM
so i just emptied the pump do you think there might be stuff in the hoses too? nothing visible in the way or in the hoses as far as i can see but I didn't actually remove pump just emptied
Old December 20th, 2008, 08:46 PM
okay Jake I figured it out! so I took off the top and tried to start another load and it was the dispenser motor in fact what it is its the cam actuator and the other piece of plastic connected to that what happens is the motor shaft rotates and the plastic piece #8540395 connected to the cam bends upwards and binds up and doesn't allow itself to rotate or open. anyhow now that i know what it is i don't know how to fix it the only way it works is if i manually move the piece#8540395 after it gets stuck
Old December 21st, 2008, 07:36 AM
Ok, glad you found the problem.
You'll need a new dispenser assembly.
Here's the dispenser assembly for your model you can order:
Manufacturer's Number: 8540058 - Dispenser
icon
Here's the parts diagram for your dispenser:
bmadsen (December 21st, 2008)
Old December 21st, 2008, 08:42 AM
ok thx for all your help appreciate it. one last question is the dispenser assembly easy to fix? and does it happen frequently?
Old December 21st, 2008, 01:15 PM
Yes, just follow the instructions in the repair manual I linked to above.
You can print those pages out as well.
I can't really say it happens frequently, its kinda rare to go out, but can happen.
Whirlpool Duet Sport 8500SR Nightmare conduit Whirlpool Brands Forum 1 November 6th, 2007 03:54 PM
[FIXED] Whirlpool Duet Sport - F 20 Error code jamfrey Whirlpool/KitchenAid 8 August 9th, 2007 08:46 AM
Whirlpool Duet Sport - door locked, need help Ltunes Whirlpool/KitchenAid 1 March 26th, 2007 07:50 AM
whirlpool duet or duet sport on second floor? satish_paddu Whirlpool 9 December 8th, 2006 10:30 PM
Whirlpool Duet or Sport? jtconte Whirlpool/KitchenAid 3 October 27th, 2006 09:37 AM
