Go Back   ApplianceBlog.com - Appliance Repair Forums > Appliance Repair Talk > Microwaves > Whirlpool/KitchenAid
Old January 14th, 2009, 08:28 AM
ratt69ss is on a distinguished road
Default Whirlpool MH6150xma
I can't use any of the buttons to heat up food except the add minute button. What's wrong?
Old January 14th, 2009, 04:31 PM
TechnicianBrian's Avatar
The ribbon cable to the touch pad may have come loose, needs to be cleaned, or one of the wires has broken. If you take the grill off and remove the screw that holds the control panel in place, then you can slide the panel up and get to the control board. There is a ribbon cable on one side you can disconnect from the board and try cleaning the contact ends with a pencil eraser, then reinstall it making sure the connector locks back in place. If that doesn't do it, then a new touch pad would be in order. Try that and verify your model number including any ending numbers if you need further assistance.
TechnicianBrian
AllTechAppliance.com
Whirlpool Duet is a Nightmare! CheerMom Whirlpool Brands Forum 2 November 3rd, 2008 09:45 AM
Whirlpool du1148xtpqa dishwasher sensing won't work dmello1284 Whirlpool 21 August 22nd, 2007 09:49 AM
Whirlpool WED9400S Drum Light nanook Whirlpool/KitchenAid 0 July 28th, 2007 05:55 PM
Done with Whirlpool & Kenmore Beyond Lemons automan1223 Sears Kenmore Brand Forum 0 March 3rd, 2007 10:57 AM
Kitchenaid vs Whirlpool? rv8 KitchenAid 1 January 25th, 2006 11:22 PM
