Old February 23rd, 2009, 10:25 AM
Senior Member
typhoon55 is on a distinguished road
Default [FIXED] tub is loose
I have a whirlpool #LA7680T - the tubseems loose and will make loud noise when spinning
Also, How to remove the the cabinet on this model?
thx robert
Old February 23rd, 2009, 10:59 AM
Hi Robert,
Sounds like your tub drive hub is stripped.
Here's the tub drive block for your model:
Manufacturer part number 389140 is RepairClinic item number 2858
389140
To get access to, and check the drive block read #2 & #7 here:
Once you remove the inner basket you can see it and get access to it.
Drive block may be worn out. This sometimes is accompanied by some strange noises as well, but a worn drive block will also stop the spin from working. You will need to remove the agitator to see the drive block.
Courtesy of http://www.applianceaid.com/direct-nospin.html
Old February 23rd, 2009, 12:17 PM
Senior Member
the washer does seem to work and spin.
there is just a loud banging noise like an uneven heavy load of clothes.
i removed the cabinet and see that the tub seems to have no right front side underneath support as the left front and back do. The tub has no suspension at that point and seems to hit the metal as a result.
Does this sound like the hub or possible the suspension pads or maybe the counter balance spring in the back?
thx robert
Old February 23rd, 2009, 03:30 PM
Senior Member
counterbalance spring hole at base rusted thru. drill a new hole and good to go
Old February 23rd, 2009, 06:51 PM
Ahh, yes, good job fixing it Robert.
Spring to balance tub
388492
How to get inner tube out of outer tub? cmoyer.work@gmail.com Sears Kenmore 1 December 27th, 2008 10:08 AM
GE WCVH6260FWW tub bent? wakramer GE/Hotpoint 1 June 13th, 2008 03:16 PM
GE Front Loader noisy/drum loose rriggs9000 GE/Hotpoint 3 July 28th, 2007 10:29 AM
FL FWT445GES0 Broken Spring Holder on tub Bedly Frigidaire/Electrolux 1 March 30th, 2007 08:27 PM
I found Skate Plate completely loose, water leak, and big bang. tommmm Whirlpool/KitchenAid 6 February 13th, 2007 10:32 PM
