Old February 24th, 2009, 01:10 AM
Dubina is on a distinguished road
Default Whirlpool LLR6144AQ0
Quirky wash cycle.
Load switch = Small
Temp switch = Hot/Cold
Normal wash, 6 minutes
Hot water shuts off at about the right load level (Small).
But timer does not advance to agitate.
I advance the timer manually to agitate.
Timer counts down toward Rinse, cold water comes on, flows for a while and then shuts off.
Timer hangs up just past Rinse. No ticking sound.
I manually advance the timer to spin.
Washer drains and spins, timer moves to shutdown.
In this case, the timer doesn't advance after the water shuts off.
Previously, however, (last week) I had a problem whereby the water wouldn't shut off. I installed a new load switch, which seems to have cured the water/load shutoff problem, but now there seems to be a problem with getting the timer to advance after the water shuts off.
I have a Whirlpool DIY Repair Manual for this washer. I'm not sure what "problem" I have now vis-a-vis the Problems in the Manual (Pages 22 to 26).
Old February 24th, 2009, 08:51 AM
Hi Dubina,
It sounds like your timer contacts are bad. You would need a new timer.
Here's the timer for your model:
Manufacturer part number 285952 is RepairClinic item number 1026027
285952
Old February 24th, 2009, 11:24 AM
Default Timer contacts
Hi Jake,
The repair manual cites a number of possible problems, including the timer. I'm inclined to think you are right, but I wonder if there's a way to check the timer contacts to be sure. The timer is an expensive part and I've already spent $100 to replace the load switch. If a new timer doesn't do the trick, I will have put up half of what a new washer would cost.
I've done some continuity checks on the timer contacts ("terminals"?). I see a 3x8 array of terminals. The second row of 8 rows has no continuity and the 8th row has no continuity. I suppose that means something, but I haven't been able to decode the wiring diagram. Do those two continuity issues mean the timer won't advance at some stage in the cycle?
Also, what about the timer motor? It's fixed to the timer, and it seems to work (intermittently, at least), but I see a funny looking cog structure on the motor that might or might not be problematic.
If I get a new timer, get one with a new timer motor?
Thanks, regards,
Old February 24th, 2009, 06:47 PM
Dubina,
We have a special return policy here.
If you order the timer from the link I posted above and it doesn't fix the problem, then you simply send it back for a FULL refund within 30 days.
The timer motor comes complete with the timer assembly.
Here's a good link from Jeff's site about how to check the timer:
http://www.applianceaid.com/direct.html#burnt_timer
Old February 26th, 2009, 08:06 AM
Default Jeff's site
Hi Jake,
When I went to Jeff's site as you suggested, I found something puzzling; maybe you can tell me what to make of it.
Jeff's site advises the lid switch can be a problem if the timer hangs. In fact, Jeff seems to implicate the lid switch more than the timer for the kind of timer hang-up that I see. If my lid switch works to shut down my spin cycle when I open the lid, can the lid switch still be bad and mess up my timer?
Thanks again.
Old February 26th, 2009, 08:54 AM
Yes, it would make the timer stall.
When you close the lid on your washer, do you hear a clicking sound just before it shuts?
Old February 26th, 2009, 09:05 AM
Default Lid switch click
I hear something but I'm not sure it's the "click" you're talking about.
When the tub is spinning, I open the lid, I hear a noise (like something mechanical being disengaged) and the tub stops spinning. When I close the lid, I hear the sound of something mechanical being engaged, but it's kind of loud and I don't detect anything that sounds distinctly like a "click".
Old February 26th, 2009, 09:22 AM
Well, then your lid switch is working if you opened up the lid when it was spinning then it stopped, then restarted when you closed the lid, the lid switch is working fine.
Old February 26th, 2009, 09:39 AM
Default Thanks Jake
I thought so, but I wan't sure. I'll order a new timer.
Old February 26th, 2009, 10:29 AM
Ok, sounds good Dubina.
Keep us posted.
Whirlpool Duet is a Nightmare! CheerMom Whirlpool Brands Forum 2 November 3rd, 2008 09:45 AM
Whirlpool du1148xtpqa dishwasher sensing won't work dmello1284 Whirlpool 21 August 22nd, 2007 09:49 AM
Whirlpool WED9400S Drum Light nanook Whirlpool/KitchenAid 0 July 28th, 2007 05:55 PM
Done with Whirlpool & Kenmore Beyond Lemons automan1223 Sears Kenmore Brand Forum 0 March 3rd, 2007 10:57 AM
Kitchenaid vs Whirlpool? rv8 KitchenAid 1 January 25th, 2006 11:22 PM
