Old February 24th, 2009, 12:27 PM
apple is on a distinguished road
Default Whirlpool LSQ9200LQ0 -- very loud spin cycle
Just today the washing machine started making a terrible noise while spinning? Is it the transmission? Drum bearing failure?
Is it worth getting fixed or just get a new machine?
Old February 24th, 2009, 06:51 PM
Your washer is a 2002 model, so its really not that old.
Sounds like your tub drive hub is stripped.
Here's the tub drive block for your model:
Manufacturer part number 389140 is RepairClinic item number 2858
389140
To get access to, and check the drive block read #2 & #7 here:
Once you remove the inner basket you can see it and get access to it.
Drive block may be worn out. This sometimes is accompanied by some strange noises as well, but a worn drive block will also stop the spin from working. You will need to remove the agitator to see the drive block.
Courtesy of http://www.applianceaid.com/direct-nospin.html
Old February 25th, 2009, 06:24 AM
Thank you.
I had a repairman out yesterday who told me that the transmission was hot and I need to get a new washer. He diagnosed the problem from the noise alone.
Is it worth having another repairman out?
Old February 25th, 2009, 07:38 AM
lol, yes of course, a hot transmission is not a diagnosis's of the problem.
Let me ask you this, how often do you use your washer? Daily? many times a day? a few times a week?
Whirlpool washer does not engage spin cycle aviation76 Whirlpool/KitchenAid 22 March 5th, 2008 10:02 PM
Whirlpool washer spin cycle problem tmfmaverick Whirlpool/KitchenAid 6 December 30th, 2007 10:18 AM
Maytag sav4655ewq, loud jet engine sound in spin cycle problems Maytag Brands Forum 2 February 15th, 2007 08:11 PM
spin cycle starts with loud clicking noise Kenmore 80 k5er Sears Kenmore 7 September 13th, 2006 10:58 PM
Whirlpool washer vibrates bad after spin cycle. mail.mcintyre@adelphia.ne Whirlpool/KitchenAid 1 May 10th, 2006 07:47 PM
