Heat turns off after about 5 minutes. Checked the venting - clean Checked the fuse - fine Checked continuity in the thermostats - fine So, based on reading other posts, I'm thinking it's the coils. I dismantled the front last night to get a look at the burner but as the drum started to slide I quickly pushed the front panel back together. What do you think? (and if testing the continuity of the coils is my next step, any suggestions on how to keep the drum in place when removing the front plate?? Last thing I need is for the drum to slide out of place onto the floor!) |
Yes, it sounds like the gas coils are bad.
You can use a big block or 2X4 to hold the dryer drum in place once the front panel is removed. You can test the gas coils for continuity, but even if it tests good, the gas coil solenoid inside can still be bad and "sticking" on you when it first heats then doesn't heat any more after 5 minutes. So the chances its the gas coils being bad is extremely likely. Here's the gas coil kit for your model you can order: Manufacturer part number 279834 is RepairClinic item number 3479 279834Jake
Best $5 I've ever spent. Replaced the coils and it works great.
Thanks. ps now i'm inspired to try and fix the kitchenaid mixer that has an electrical problem and won't start! Any tips??? |
Excellent, good job fixing your dryer.
![]() Sorry, don't have a clue about how to fix mixers. Jake
| Whirlpool electric in wall oven will not heat | bullittandy | Whirlpool | 7 | February 27th, 2009 06:57 PM |
| Whirlpool RBS305PDQ10-No Heat on any setting | rexcars27 | Whirlpool | 7 | January 24th, 2008 05:48 AM |
| Heat goes out on my Whirlpool LGQ8000HQ0 gas dryer | oldtoys1961 | Whirlpool/KitchenAid | 3 | November 28th, 2007 10:54 PM |
| Whirlpool Electric Range shorted out half my apartment and now does not heat | Gargy30 | Whirlpool | 1 | July 29th, 2007 09:57 AM |
| Whirlpool oven very slow to heat up | albritton | Whirlpool | 10 | November 3rd, 2005 10:16 AM |
