Old March 12th, 2009, 10:20 AM
dwgrau is on a distinguished road
Default [FIXED] Whirlpool AccuDry problem
Re: Whirlpool Model #WED5860SW0
When using AccuDry setting, clothes will continue to dry in any setting in this cycle, but timer doesn't advance. Clothes are hot and temperature seems constant.
When turning knob to both wrinkle shield settings, the timer works. Timed drying works fine.
Haven't done any troubleshooting yet. Don't have a detailed manual.
Dryer exhaust pipe is free and clear and lint filter is cleaned after every use.
Old March 12th, 2009, 02:11 PM
If your absolutely sure your vent is clear and lots of air is blowing outside good, then its likely your control board thats bad, which causes the timer not to advance in auto-dry.
Part#3390537
Electronic dryness control board
(The manufacturer has replaced part number 3390537 with this item, part number 8558178.)
Old March 13th, 2009, 05:40 AM
Smile AccuDry Problem Response
The vent is good. I replaced the outside cover recently with a free flowing vent so alot of unrestricted air flow. I'll also check the wiring to control board. Moisture sensor not likely to fail?
Thabnks alot for your fast reply,
Dennis
Old March 13th, 2009, 07:35 AM
No Dennis, I don't think I've ever seen the moisture sensor fail itself.
Old March 13th, 2009, 10:26 AM
Default AccuDry Problem
I agree with your sensor response. I have found, that most electronic circuit board failures generally occur during the so called "burn in" period. Guess 24 months for dryer control boards falls within this time frame! Nowadays, I'm not surprised. I appreciate your help! I'll post again when dryer is working.
Dennis
Old March 13th, 2009, 06:37 PM
Sounds good Dennis, and if you order the part from the link I posted above and it doesn't fix the problem, you can return it within 30 days for a FULL refund.
Old March 15th, 2009, 05:14 AM
I pulled the dryer out and cleaned out the lint in the exhaust and hose. Although free flowing, there was quite a bit of lint. After seeing this, I will clean out once a year. The control board has two burned resistors. Has the new part #. Found take off boards old # from an outfit in Florida. Since really cheap, I ordered 2. Will see.
tks,
Dennis
Old March 15th, 2009, 09:26 AM
Ok Dennis,
You can order it from the link I posted above, just to be on the safe side. Part#3390537
Are the 2 boards you ordered have a warranty in case they don't work? Sometimes if you find a control board alot cheaper, it may be either used or something, I'd be careful.
Old April 2nd, 2009, 05:03 AM
Smile Control Board
The control board was replaced. AccuDry setting works fine.
Thank's Jake for your help.
Old April 2nd, 2009, 08:35 AM
Excellent, good job Dennis.
Whirlpool duet GHW9100 Electronics Problem dc013 Whirlpool/KitchenAid 10 April 10th, 2008 08:27 PM
Whirlpool GS6NBEXRL00 Ice Dispenser problem davidlduval Whirlpool 5 February 13th, 2008 09:16 AM
Whirlpool washer spin cycle problem tmfmaverick Whirlpool/KitchenAid 6 December 30th, 2007 10:18 AM
Whirlpool Icemaker Problem rpmartin Whirlpool 3 July 22nd, 2007 07:57 PM
Whirlpool Direct Drive Timer Problem chatparle Whirlpool/KitchenAid 3 January 29th, 2007 11:29 AM
