August 17th, 2009, 10:47 PM
Whirlpool Gold Mic/Oven ~ Remove control panel
How do you remove the control panel on the Whirlpool Gold Upper Microwave/Combination Lower Oven? Model choices:
RMC275PD/RMC305PD
GMC275PD/GMC305PD
Thank you.
August 18th, 2009, 06:40 AM
Open the oven door and you will see screws holding the side trim in place. Removing the screws and trim will expose the screws holding the side of the panel in place. The panel will lift up and forward. Best to loosen the screws holding the entire unit to the cabinet and pull it away enough to prevent damage to the cabinet.
August 19th, 2009, 01:03 AM
Thanks, Brian. Much more involved than I was hoping.
August 19th, 2009, 06:15 AM
By INXS9000RPM in forum Bosch
Last Post: May 20th, 2008, 11:08 PM
By BobP in forum Whirlpool
Last Post: April 9th, 2008, 10:43 PM
By Austinpowers in forum Sears Kenmore
Last Post: July 23rd, 2007, 08:35 PM
By fast65 in forum Whirlpool/Roper/Estate
Last Post: May 3rd, 2007, 09:47 AM
By dougC in forum Whirlpool
Last Post: January 11th, 2007, 10:15 AM
