Hello all,
I have spent a number of hours searching this wonderful site for a solution to my problem. My whirpool dryer won't heat. I found many threads with the same problem and most were fixed by replacing the thermal fuse. I have a gas dryer numbers are: Model #: LGR4634EQ3 Serial #: MJ3347385 Type: B433-NAT-1206006-FM22 Keep in mind that it is set up to run off Propane. I have cleaned the exhaust vent from top to bottom and the entire back of the dryer. I changed the thermal fuse, it started heating. I put a load in to be dried and 2 hrs later it is still running. So I open the door to check the clothes. All were still wet and to my surprise cold. I restart the cycle and popped the peep hole cover off the front and the coil is glowing indicating that it is hot and poof (this actually startled me because I wasn,t expecting it that soon), I have fire to heat with. Seeing that I find it hard to remain in a bent over kneeling position for too long on a tile floor. I came back in five mins. and the fire is out and coil is not glowing. I assume it is a gas flow issue seeing it is basically the same problem in this post [FIXED] Whirlpool LGQ9858LWO - Heat Turns Off If I am correct this is the part I need. Am I correct? Seeing that I use LP would I have to modify this part? |
Yes, it sounds like the gas coils are bad. Yes, that is the correct part for your gas coils. Manufacturer part number 279834 is RepairClinic item number 3479 279834Let us know what happens. Jake
Thank you for the confirmation Jake. I will let you all know how it goes when the part arrives.
Ok, sounds good.
Part arrived on Wednesday, installed it yesterday. Today my clothes are dried when the washer is finished. Man it is nice to have a normal dryer again. Many thanks to all those associated with this wonderful site.
Excellent Nightspear, good job.
LinkBack to this Thread: http://www.applianceblog.com/mainforums/whirlpool-kitchenaid/16416-fixed-whirlpool-dryer-wont-stay-heated.html
| Whirlpool/KitchenAid on Appliance Blog Forums | BoardReader | This thread | Refback | August 31st, 2009 11:20 AM | |
| Dryer stops with Auto-High Setting on Whirlpool | scottB_44 | Whirlpool/KitchenAid | 5 | October 18th, 2007 12:55 PM |
| Whirlpool Gas Dryer Burner won't stay Lit | digitaldriver@hotmail.com | Whirlpool/KitchenAid | 3 | September 26th, 2007 10:27 AM |
| Whirlpool Gold Dryer wont stay on | hiddenknoll | Whirlpool/KitchenAid | 1 | April 15th, 2007 04:23 PM |
| Whirlpool dryer wont stay on for an extended time | Donwizz | Whirlpool/KitchenAid | 3 | September 19th, 2005 03:35 AM |
| Whirlpool Dryer gets Warm not Hot, Takes long to Dry | jnicosia | Whirlpool/KitchenAid | 4 | August 19th, 2005 08:48 PM |
