Old September 4th, 2009, 09:45 AM
swebeaux is on a distinguished road
Default [FIXED] whirlpool FWF9200SQ00 F 70
2 yr old washer quit working and displayed F70.which is a heartbeat error, the door was locked and the machine responds to nothing on the key pad. Diagnostics cannot be entered. The tech sheet said to replace the central control board if the drum was not turning. So this is what I did. The machine came on as it should. Pushed the machine back into place and it quit working. continuity has been checked between the central control and the user interface. I'm now assuming the user interface needs to be replaced, but there are 2 user interfaces can someone tell me what I should do next
Old September 4th, 2009, 02:24 PM
Please double check your model# again, I can't pull that one up.
Old September 5th, 2009, 07:00 AM
Default model number correction
the prefix is wfw not fwf
Old September 5th, 2009, 10:02 AM
Ok so your model# is WFW9200SQ00
I haven't run into this F70 error code on this newer model HE5, but from reading other posts on our site and other sites, its looking like is a user interface problem like you mentioned, but I'm not sure which user interface is the problem.
You can order both of them listed here and return the one you don't need for a full refund within 30 days.
Here's the center user interface for your model:
Manufacturer's Number: W10168596
icon
Here's the right side user interface for your model:
Manufacturer's Number: W10191965
icon
Old October 1st, 2009, 05:35 PM
mrtivo is on a distinguished road
I also have a 2 year old duet (same model.) I am getting the same error. I took apart the lower pump cleanout and found a small wash rag. Is there a way to diagnose which part is giving me the error? It seems similar to the issue of the original poster. Is it possible the washrag damaged the pump and that is what is causing the error?
If you have a 30 day return policy for parts, I probably should order both control boards and the pump, see which is causing the problem, and then return the items not needed?
any help/comments are much appreciated.
thanks,
Old October 1st, 2009, 08:32 PM
Not that I'm aware of.
Yes, all parts you order through our site come with a 30 day full refund installed or not.
Here's the water pump for your model:
Manufacturer's Number: 280187
280187
mrtivo (October 2nd, 2009)
Old October 2nd, 2009, 04:59 AM
Thanks Jake!
Old October 2nd, 2009, 08:31 AM
Glad to help mrtivo.
Keep us posted.
Old October 2nd, 2009, 06:48 PM
I found the service sheet in the waher and checked th e continuity of the pump. It is where it should be. According to that, and the F70 error, it states that i need to replace the CCU. Is that this part?
thanks
Old October 2nd, 2009, 08:38 PM
Here's the CCU for this model:
Manufacturer's Number: 8183258
icon
LinkBack to this Thread: http://www.applianceblog.com/mainforums/whirlpool-kitchenaid/16476-fixed-whirlpool-fwf9200sq00-f-70-a.html
Posted By For Type Date
Whirlpool/KitchenAid on Appliance Blog Forums | BoardReader This thread Refback September 8th, 2009 10:39 AM
Whirlpool Duet is a Nightmare! CheerMom Whirlpool Brands Forum 2 November 3rd, 2008 09:45 AM
Whirlpool du1148xtpqa dishwasher sensing won't work dmello1284 Whirlpool 21 August 22nd, 2007 09:49 AM
Whirlpool WED9400S Drum Light nanook Whirlpool/KitchenAid 0 July 28th, 2007 05:55 PM
Done with Whirlpool & Kenmore Beyond Lemons automan1223 Sears Kenmore Brand Forum 0 March 3rd, 2007 10:57 AM
Kitchenaid vs Whirlpool? rv8 KitchenAid 1 January 25th, 2006 11:22 PM
