My dryer stops after a few minutes of drying and an error code, E1, is shown in the display. I can restart and it runs for a few minutes and shuts back off, taking many restarts to actually dry a load of clothes.
Probably related to this problem is the display on the matching washer that doesn't work right now either. I believe I may have had some sort of power surge or something because both problems began within a few days of each other. any ideas as to what the problem may be? Thanks, Andrew |
Hi Andrew,
E1 means: Thermistor Failure. You will need to replace this. Here's the one for your model you can order: Manufacturer part#8577274 is RepairClinic item#1181075 8577274You would need to take off the lower front access panel under your door, then take off the duct assembly#45, by removing the two #32 screws, and remove the #2 screw at the very bottom of the duct assembly with a bracket#11 attached to it, remove that one also. Unplug your dryer first! Then your thermistor is #42 on the blower housing, next to your thermal fuse#59. ![]() Jake
LinkBack to this Thread: http://www.applianceblog.com/mainforums/whirlpool-kitchenaid/16544-whirlpool-duet-dryer-model-ggw9200lw0-error.html
| Whirlpool/KitchenAid on Appliance Blog Forums | BoardReader | This thread | Refback | September 30th, 2009 04:28 PM | |
| Whirlpool Duet & Whirlpool Duet Sport Dryer - Repair Manual | Jake | Whirlpool/KitchenAid | 2 | January 12th, 2010 08:38 PM |
| [FIXED] whirlpool duet dryer start problem | bnvdvr | Whirlpool/KitchenAid | 7 | April 26th, 2009 06:25 AM |
| Whirlpool Duet HT Washer F-11 error code | ginawg | Whirlpool/KitchenAid | 5 | October 13th, 2008 02:25 PM |
| F20 error on BRAND NEW Whirlpool Duet Steam Washer | mikemilw | Whirlpool/KitchenAid | 7 | January 22nd, 2008 07:16 AM |
| Whirlpool Duet F 21 Error | ddutton | Whirlpool/KitchenAid | 4 | September 2nd, 2007 03:55 PM |
