Results 1 to 4 of 4
Thread: Intermitant Stop - Start
    JGHarper is offline Premium Member
    Apr 2010
    Texas
    Default Intermitant Stop - Start
    Model Number: KBMS1454RSS 0
    Brand: KitchenAid
    Hi, my kitchenaid microwave, once started, sometimes starts, stops then restarts...multiple times. It's like it has an electrical short. Also, the clock is losing about three minutes / day, so I think electricity may be getting cut off momentarily, as well?
    The microwave cooks fairly normal, but just with fits and starts! Thanks for your help.
    Apr 2010
    Texas
    Bump!
    Hi JG,
    I don't work on microwaves, but I'll see if Jeff can help you.
    Oct 2004
    Not overly familier with this style....many of these or not up here with me.
    Kicking in and out....one would/should check things in the main power.....house wire ( something loose ), plug/outlet, line filter, fuse/fuse holder ( inside the unit ), cold solder joint on the board, etc.
    I found a Tech sheet manual on line.
    http://www.applianceaid.com/
    NEW Appliance Repair Aid
    http://www.jrappliance.ca
    JRAppliance
  1. Replies: 233
    Last Post: October 20th, 2011, 11:46 AM
  2. [FIXED] Kenmore HE2 washer stop and will not start again?
    By spectorequipment in forum Sears Kenmore
    Last Post: May 25th, 2010, 10:09 PM
  3. Start windings appear to be bad- Again !!!
    By slalomdude in forum Sears Kenmore
    Last Post: January 29th, 2010, 10:12 AM
  4. Dryer won't start.
    By Jeff Jobe in forum Sears Kenmore
    Last Post: April 17th, 2009, 10:12 AM
  5. Whirlpool dryer will not start...
    By STS1SS in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: August 24th, 2007, 10:56 PM
