I have an Estate by Whirlpool - model # TEDS740JQ1
the dryer will not heat. I checked the exhaust, replaced the power cord, the heat element, the thermal fuse, and the therostat on the heat element. I may have been jumping the gun a little, but now I just learned that I could test using a meter. Also, the timer is not moving, which I learned could be a cause of the dryer not heating. Is this true? I probably wasted money on other parts when I didn't have to and should of realized I need to replace the timer. Should I buy a meter and test the timer? If it is not moving, what are the causes? Thank you |
dryer tumbling and i've checked all limits ,fuses and resisters are within specs.having problems with timer shutting off.
Testing with a volt/ohm meter is best way to check what parts are good and which are bad. ![]() I will give you both a link about what to test and check on dryers: http://www.applianceaid.com/dryers.html Jake
| Kenmore 110.70712990 Gas Dryer Timer Doesn't Stop & Won't Heat | Irelnd4evr | Sears Kenmore | 5 | June 16th, 2007 03:49 PM |
| Maytag DE312 no heat or timer | RavenNorth | Maytag/Magic Chef/Admiral/Jenn-Air | 8 | April 17th, 2007 07:56 AM |
| Kenmore Elite Ser. 70 Dryer 110.67612690... Timer Stops and no heat | BaerEssentials | Sears Kenmore | 1 | December 26th, 2006 09:40 PM |
| Kenmore 70 Series timer not moving & no heat | yosemity71 | Sears Kenmore | 3 | August 21st, 2006 02:24 PM |
| LTE6234AW2 - no heat / timer doesn't work | JWilliams | Whirlpool/KitchenAid | 5 | August 12th, 2005 10:49 PM |
