Old January 14th, 2006, 06:19 AM
originalboxcar is on a distinguished road
Default Gas dryer timer will NOT stop
Problem:
Whirlpool Gas (lp) dryer model LGR4624BQO timer will NOT stop moving (turning).
Symptoms:
The dryer itself will only stop when the timer reaches the stop positions on the dial but the timer itself will keep turning and then once it reaches the begining of the next cycle the dryer will start on its own again. The only way I can prevent this is to leave the dryer door open and the door switch keeps the dryer from restarting but the timer keeps moving irregardless. If I put my ear down to the timer, I can actually hear the timer running. If I start a new load/cycle after the timer has been in the off position, then I need to push the start button.
I haven't seen this particular scenario in the forum so I thought I'd post for an answer. Any help would be appreciated. Thx!
t~
Old January 14th, 2006, 07:30 AM
Sort of sounds like you have contacts welded inside of the timer that should be opening in the off position...
Kenmore 110.70712990 Gas Dryer Timer Doesn't Stop & Won't Heat Irelnd4evr Sears Kenmore 5 June 16th, 2007 03:49 PM
Kenmore 70 series gas Dryer not heating right pflowers Sears Kenmore 1 February 12th, 2007 07:14 PM
Kenmore Elite Ser. 70 Dryer 110.67612690... Timer Stops and no heat BaerEssentials Sears Kenmore 1 December 26th, 2006 09:40 PM
Help a proud man conquer his Series 70 gas dryer ianski Sears Kenmore 13 December 7th, 2006 12:02 AM
Kenmore 90 Series Gas Dryer Problem HomeRepairGreenhorn Sears Kenmore 9 March 15th, 2005 01:02 PM
