February 13th, 2012, 11:37 AM
KitchenAid Microwave Hood combo - no lights, doesn't work but clock and timer work
It seems as though there is power to the unit, but the lights do not work. I tried to heat food the other day and it allowed me to enter a cook time and even started to count it down when I hit start, but the unit was not functioning?
I've read the horror stories about units turning on on their own and running for hours and now I'm very concerned about this unit. I'm wondering if anyone has ever come across anything like this and can shed some light on it. It is out of warranty, so I'm on my own for repairs, unless it's a recall issue.
Thanks.
February 13th, 2012, 02:27 PM
Ok, so I took off the pad cover to look so obvious signs of problems. While the panel was off, I tried the lights and they worked. so I thought loose connections somewhere and checked. I didn't find any, but figured that may have been the issue. Well, not so much. The fan doesn't work and neither does the heating function. A web search suggests others have had this issue and it was related to the board being bad. Before I go down that road, I'm wondering if anyone has dealt with this?
Brian
February 13th, 2012, 06:56 PM
That is normally an door switch/door switch mechanism problem.
LINK> Microwave repair information and lots of questions and answers, magnetrons, capacitors, common microwave problems, what might be wrong with my microwave, microwave fault codes, F1, F2, F3
LINK> CAUTION WHEN REPLACING LATCH SWITCHES
LINK> Most microwave door switches can be tested for continuity to see if the switch has failed
Thta is part of a full model#.....17 models start with those digits.
February 14th, 2012, 02:21 PM
Okay, so along with not heating, the fan does not work. Is that still a latch switch issue?
February 14th, 2012, 06:39 PM
More times than not....control counting down, light may be on or off, no fan, no cooking and no turntable is a door switch/door switch mechanism problem.
February 17th, 2012, 05:14 PM
Ok, I changed out the switches and still no fan or heating? Any other places I should look?
February 17th, 2012, 06:19 PM
Did any prove to be bad? How where they checked?
What is happening...exactly?
February 17th, 2012, 07:51 PM
Originally Posted by
jeff1
I checked them for resistance and got it with them both opened and closed.
Presently, what's not working in the fan and it's not heating. The turntable works, the lights work, timer, clock all work.
February 18th, 2012, 05:37 AM
They checked ok?
Recheck the upper switch, make sure the door latch is tripping the upper most switch....if it is and the correct switchs are closed when the door is open and correct switches are open when the door is opened the smart board would be the next suspect.
February 18th, 2012, 06:51 AM
jeff1
They checked ok?
I don't think so. I got resistance with them opened and closed, so think that means that they are preventing the current from flowing thru which would prevent the oven from functioning properly.
I was fiddling with the door when the unit was running (not heating but turntable, light and vent working) and it shut off when I pushed the door up. I assume that is the switch indicating that the door is not closed properly so it defaults to shutting down. I thought that that made sense with regards to safety and assume it was operating correctly.
I'm wondering at what point I should pull the trigger on replacing the microwave instead of repairing it. It seems like there are enough problems with this manufacturers and model that this isn't going to be the only time it craps out on me.
By thefatguythatpaysthebills in forum Whirlpool/KitchenAid
Last Post: November 16th, 2011, 05:00 AM
By feelingrippedoff in forum Whirlpool/KitchenAid
Last Post: September 25th, 2011, 04:46 PM
By pittguy578 in forum Whirlpool/KitchenAid/Roper/Estate
Last Post: May 14th, 2011, 01:33 PM
By Paul79UF in forum Sears Kenmore
Last Post: March 6th, 2008, 11:35 AM
By JWilliams in forum Whirlpool/KitchenAid/Roper/Estate
Last Post: August 12th, 2005, 11:49 PM
