Results 1 to 4 of 4
Thread: Accessing microwave
    Waccamaw is offline Premium Member
    Jul 2012
    South Carolina
    Default Accessing microwave
    Model Number: KEMC307KSS05
    Brand: KitchenAid
    We have a Kitchenaid KEMC307KSS05 combo oven and microwave. After a power outage the microwave displays DOOR when you try to operate it. Reading other posts the fuse or fuses and the door switch need to be checked.
    Is the microwave accessible from the front or do I have to remove the whole combo from the cabinet? Your advice will be appreciated.
    rickgburton's Avatar
    Jul 2006
    Murray, Utah, United States
    Quote Originally Posted by Waccamaw View Post
    Sounds like a faulty interlock switch.
    Disconnect the electrical power to the microwave/oven combination. Open the lower oven door. Remove the bottom screw from each of the two side trim pieces. To remove the side trim, pull the bottom out approximately 2˝, and slide the top down to free it from the control panel. Remove the screws from the oven control panel. To remove the oven control panel, pull it out at the bottom, and lift and unhook it from the oven cabinet support at the top. Open the microwave oven door and remove the glass turntable and roller assembly from inside the oven cavity. Leave the oven door open. Remove the three screws from the upper air vent and remove the air vent. Remove the four screws from the lower air vent and remove the air vent. Close the microwave oven door. Pull the microwave oven out of the oven cabinet approximately four inches. Disconnect the two red LOAD wires from the microwave light power supply, the 6- pin connector, and the green ground wire in the top of the oven cabinet. Slide the plastic grommet and the microwave oven out of the oven cabinet and set the oven on your work surface.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Jul 2012
    South Carolina
    Rick,
    I checked the 3 microswitches, replaced one. I still get the "DOOR" message when I try to use it. Do you have any other suggestions?
    Thank you!
    Jul 2006
    Which switch did you replace and did you check them with at least one wire removed from the switch? Check the switches by opening and closing the door to make sure the door latch is doing it's job. It still sounds like a door switch problem to me but if you checked them and they're working properly then the control board must be faulty.
    Oven Control Board 8302346 Order now for same day shipping. 365 day return policy. RepairClinic.com
  1. FIXED: Maytag gas oven - accessing the bake ignitor
    By Erin Mitchell in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: October 29th, 2012, 12:18 PM
  2. Need help accessing Subzero defrost drain hose to clean it
    By cbresadola in forum Refrigerators & Freezers
    Last Post: January 12th, 2012, 05:48 PM
  3. [FIXED] Accessing pump on Frigidaire # FTF2140ES0
    By theripster in forum Frigidaire/Electrolux
    Last Post: November 26th, 2008, 08:23 PM
  4. Accessing touch panel GE JKP15BOW1BB
    By jag_man653 in forum GE/Hotpoint
    Last Post: May 8th, 2008, 05:22 PM
  5. Accessing pump on Kenmore washer/dryer combo
    By cmartz in forum Sears Kenmore
    Last Post: March 25th, 2006, 06:53 PM
