Old September 29th, 2006, 06:01 PM
Josh1001 is on a distinguished road
Default Roper (Whirlpool) RAX4232KQ0 Washer Won't Drain or Rinse
My Roper RAX4232KQ0, Type: 107, fills with water, goes through the wash portion of the cycle, and then gets to the rinse portion and stops. It won't drain or spin in any of the 4 cycles and the water has to be syphoned out. I can hear (and see) the timer moving along until about halfway through the rinse portion, then it also stops completely. Any idea what may be the problem and how to fix it?
Thanks.
Old September 30th, 2006, 06:10 AM
G'day,
Ckeck the lid switch and/or lid switch probe. If the lid switch fails and spinning and draining will quit but the filling and agitation will still work...
Lid switch assembly
Access helps...
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Old September 30th, 2006, 10:46 AM
Yep, the assembly was broken where the screws attach the switch to the machine right under the lid. As you can probably tell, my mechanical aptitude is quite low!!! Thanks for the quick and easy diagnosis.
Old October 1st, 2006, 06:20 AM
Thankx for the update!...your welcome
JRAppliance
Drain problem with my Whirlpool washer. Romen3 Whirlpool/KitchenAid 1 November 5th, 2006 01:09 AM
Kenmore Elite Catalyst washer won't drain & spin Brittgee Sears Kenmore 1 August 24th, 2006 04:04 PM
Whirlpool Washer not Spinning limetwist Whirlpool/KitchenAid 22 May 17th, 2006 05:30 PM
whirlpool calypso washer won't drain futurevip Whirlpool/KitchenAid 1 March 12th, 2006 02:08 PM
Another Whirlpool Dishwasher won't drain rickm Whirlpool 1 August 9th, 2005 12:11 AM
