Results 1 to 4 of 4
Thread: Whirlpool Microwave MH6150XHB-1 turntable stopped
    RockwallMike is offline Member
    Oct 2006
    Rockwall, TX
    Default Whirlpool Microwave MH6150XHB-1 turntable stopped
    Howdy,
    Glad I found your forum--you all are awesome! I have a problem with the turntable in our Whirlpool MH6150XHB (mfg 2001). It just stopped turning, and now occasionally the entire unit hums quite loudly. It still works ok--just has a few more hotspots... Is there a user-replaceable part to get my turntable working again, or am I stuck buying a whole new unit? Any suggestions would be greatly appreciated!
    Mike
    Oct 2004
    Make sure the drive block is not cracked and that the wheels are not broken or jammed up....failing those....power to the turn table motor tested with a volt meter and no go = new motor time.
    The motor is accessed from below.
    Motor, turntable
    http://www.applianceaid.com/
    NEW Appliance Repair Aid
    http://www.jrappliance.ca
    JRAppliance
    Oct 2006
    Rockwall, TX
    Thanks! I'll take a look and see if I can get that base plate off. Do you know where I can access a tech manual?
    Oct 2004
    There will be a tech/wire sheet inside the unit....usually rolled up in the control area.
    JRAppliance
  1. Whirlpool Microwave MH1150XMB-1
    By RobD7 in forum Whirlpool/KitchenAid
    Last Post: December 17th, 2006, 12:00 PM
  2. Whirlpool Microwave G2 Error code, F7
    By cmccoy11 in forum Whirlpool/KitchenAid
    Last Post: November 30th, 2006, 05:13 AM
  3. Whirlpool Microwave Issue
    By barbh in forum Whirlpool/KitchenAid
    Last Post: October 23rd, 2006, 05:04 AM
  4. Whirlpool Ice Maker Stopped Working
    By Sri in forum Whirlpool/Roper/Estate
    Last Post: September 13th, 2006, 11:23 PM
  5. Whirlpool icemaker stopped working
    By marino420td in forum Whirlpool/Roper/Estate
    Last Post: July 13th, 2005, 10:22 PM
