July 26th, 2008, 01:56 PM
Door Ice Maker Not Dispensing
I have a Whirlpool Conquest SxS which recently refuses to dispense any ice. There is no sound when the ice dispenser lever is actuated. The water dispenser works fine.
I used the in-door ice system manual so graciously provided by this forum but I've noticed some discrepancies between the manual and my ice system. Suspecting that the dispenser motor may be faulty, I removed the panel and discovered that while the manual indicates 5 or 6 wires going to the motor, mine only has four. The wiring is as follows...
Pin Color
- Brwn/Wht
- Red/Wht
- nc
- nc
- Gray
- nc
- Blue
I get 115VAC when measuring between the Blue and the Gray (pins 5 & 7) when the ice lever is pushed but I get a DC voltage which jumps around .5 VDC and 2.3VDC on pins 1&2.
Does this sound like a bad motor? Also, where is the rectifier located?
Thanks for any help you can offer,
Robert
July 26th, 2008, 10:26 PM
Hi Robert,
Here's the data sheet on your electronic dispenser:
http://adcxns1.whirlpool.com/Service...24-27_UD24.pdf
July 27th, 2008, 05:04 AM
This diagram makes a lot more sense. Let me see what I can do with this.
July 27th, 2008, 10:24 AM
Ok, sounds good, let us know how it goes.
July 27th, 2008, 04:07 PM
Hi Jake: Motor was just frozen. A quick thaw and a drying out solved the problem. I have ice through the door again;-)
Thanks again,
Robert
July 27th, 2008, 09:28 PM
Good job Robert.
Here's the ice dispenser motor for your model, in case you need to order it:
Whirlpool 2252129 Dispenser, Motor - AppliancePartsPros.com
2252129
By mjaski in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: April 18th, 2013, 07:37 PM
By Mschoaf in forum Sears Kenmore
Last Post: February 18th, 2013, 03:22 PM
By aero993 in forum Frigidaire/Electrolux
Last Post: November 20th, 2011, 08:42 PM
By remmi in forum Whirlpool/Roper/Estate
Last Post: May 2nd, 2011, 05:35 PM
By mscott327 in forum Whirlpool/Roper/Estate
Last Post: December 23rd, 2010, 08:13 PM
