Results 1 to 2 of 2
Thread: Water Dispenser not working
    Jaxhunter is offline Member
    Jun 2010
    Chestermere
    Default Water Dispenser not working
    Model Number: GD5SHAXNB00
    WAter dispenser stopped working. checked switch at water dispenser and it is closing and has 115 thru it. checked solenoid with wiring disabled 330 ohms resistance. Made water switch continuous and was getting 115 volts sporatically at the solenoid valve. After about 2 minutes it stopped short cycling and was working. After leaving it for a while it starts short cycling again.
    Thats odd, don't think I've run across this type of issue, but it sounds like possibly the dispenser control board may be acting up.
    Here's the data sheet on your electronic dispenser:
    http://adcxns1.whirlpool.com/Service...24-27_UD24.pdf
    Here's the control board#15 for your model, in case you need to order it:
    Control board - Part# W10184871
  1. Replies: 7
    Last Post: January 3rd, 2011, 07:24 PM
  2. Kenmore fridge water dispenser not working
    By sarickard in forum Sears Kenmore
    Last Post: February 1st, 2009, 03:30 PM
  3. Kenmore 253 Water dispenser not working
    By Raffo in forum Sears Kenmore
    Last Post: September 25th, 2007, 09:40 AM
  4. Kenmore refrigerator water dispenser drips
    Last Post: February 6th, 2007, 07:57 PM
  5. Kitchenaid Water Dispenser not Working
    By jdp107 in forum KitchenAid
    Last Post: June 11th, 2006, 01:29 AM
