August 4th, 2011, 03:10 PM
Problem with dispensers & LED lights are not lit?
I have the Whirlpool Gold Conquest side by side and today the water filtration system has LED lights that are always lit green for the water and ice maker but now theres no light. the filter light was yellow. and the water/ice dispenser does not work anymore, but the ice maker is still working, i did an optics test and it was working fine, i'm not sure what i should check next, should i take a look at the water valves?
August 4th, 2011, 06:44 PM
Thats odd, don't think I've run across this type of issue, but it sounds like possibly the dispenser control board may be acting up.
Here's the data sheet on your electronic dispenser:
http://adcxns1.whirlpool.com/Service...24-27_UD24.pdf
Here's the control board#15 for your model, in case you need to order it:
Control board - Part# W10184871
By Jim Smith in forum GE/Hotpoint
Last Post: July 8th, 2009, 10:38 PM
By iwanano2 in forum Sears Kenmore
Last Post: September 15th, 2007, 12:27 PM
By Labonte18 in forum GE/Hotpoint
Last Post: September 7th, 2007, 01:02 PM
By CajunFrog in forum KitchenAid
Last Post: August 22nd, 2006, 10:43 AM
By MayWork in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: December 3rd, 2005, 09:53 PM
