December 18th, 2011, 07:54 PM
Whirlpool Gold no lights in fridge help
Hi
My fridge works fine other than no lights in the non freezer side and temperature control does not light up. New bulb did nothing. Checked door switch for continuity and it works as it should.
What else should I check? Any other switches I should be aware of? or fuses?
Reason: Corrected model#
December 18th, 2011, 11:07 PM
Recheck your model#, nothing pulls up on that one.
Click here:
Help Me Find My Model Number - RepairClinic.com
December 20th, 2011, 04:13 AM
sorrty, corrected model number is QD5SHAXNQ00
December 20th, 2011, 10:05 AM
That Q should be a G.
Then it pulled up.
The problem is your control board, it will need to be replaced.
Here's the control board for your model you can order:
Manufacturer's Number: W10135090
W10135090
Unplug your refrigerator first! Just pull your refrigerator out from the wall and take off the lower back access panel and you will see the control box on the right side.
Its #18 here, located in the back of your refrigerator inside the control box#19:
January 3rd, 2012, 04:43 PM
Jake -
thanks for the reply.
Before I buy it, is there any way to check the old board? i have a digital Volt/ohm/amp that I use on about anything. Do you have a schematic with the output terminals and what they should read?
Paul
jake
January 3rd, 2012, 06:19 PM
Nope Paul, no way to check it that I'm aware of.
Don't worry the new control board will fix it, I've replaced a few of these same control boards and it always fixed it, and other members here have done the same.
January 6th, 2012, 08:56 AM
Thanks for the great information and I will order the board and advise.
Another issue which I am not sure if its related has popped up as the temperature dropped outside. When the compressor kicks on, there is a pumping sound that starts and then stops after several minutes. Its loud enough to be an irritant, and only seems to occur when cold outside. The Refrig is against a wall that backs up to the garage which is insulated. Is this due to lack of temperature control, or a bushing thats gotten cold and split?
Any ideas to resolve would be helpful.
January 6th, 2012, 12:16 PM
That just sounds like normal compressor sounds, don't worry about that, as long as it still cools fine your ok.
April 4th, 2012, 06:47 PM
I have a whirlpool gold SxS as well and I have the same issue (no lights, no digital display, nothing) except that I also have a weird clicking noise but only when I open the door. It seems like the sound is coming from the part labeled eecon tsd-115/127v 60hz. Just not sure why no lights of any kind in frig. Please help
April 4th, 2012, 07:39 PM
Hi Denise, we need the model# of your refrigerator, click here to locate it: Help Me Find My Model Number - RepairClinic.com
By Rhino in forum Whirlpool/Roper/Estate
Last Post: September 23rd, 2011, 12:55 PM
By jkraus61 in forum Whirlpool
Last Post: September 9th, 2011, 07:31 PM
By stonz22 in forum Whirlpool/Roper/Estate
Last Post: March 12th, 2011, 05:07 AM
By fast65 in forum Whirlpool/Roper/Estate
Last Post: May 3rd, 2007, 08:47 AM
By ba_feitl in forum Whirlpool
Last Post: August 31st, 2006, 09:42 AM
