Results 1 to 10 of 10
Thread: Whirlpool Gold GS6NBEXRL00 Ice Maker not making ice
    Jan Adams is offline Member
    Jan 2012
    Chandler, Indiana, United States
    Default Whirlpool Gold GS6NBEXRL00 Ice Maker not making ice
    Model Number: GS6NBEXRL00
    I have a Whirlpool Gold GS6NBEXRL00 Refridgerator that is not making ice. In previous posts I have learned that the following information might be needed to diagnose my problem: no ice in the icemaker and the ejector blades are pointing out toward me and the led lights are flashing twice then a one second delay.
    Would appreciate any infomation as to the problem and solution.
    -Jan
    rickgburton's Avatar
    Jul 2006
    Murray, Utah, United States
    Open the freezer door and check the status LED 2 Blinks followed by a 1 second delay-repeated: Tape the emitter door back so it doesn’t block the beam 2 Blinks followed by a 1 second delay: Bad optics Part# 4389102 (Ice Level Control Board 4389102 Order now for same day shipping. 365 day return policy. RepairClinic.com) LED is on steady: Optics good
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
  3. The Following User Says Thank You to rickgburton For This Useful Post:
    Jan Adams (January 12th, 2012)
  4. #3
    Jan 2012
    OK. When we open freezer the led's are doing the two blink, one delay thing. Closing that little door on the left causes the led to stay on. That little door is loose and looks broken on the top hinge now that I look at it.
    Does this mean the optics are good? Should it make ice if light is steady and I need to replace that little springed door?
    -Jan
  5. #4
    Jul 2006
    It sounds like the optics are good. If the flapper is broken then that would be the problem:
    Cover 2198633 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Whirlpool Gold GS6NBEXRL00 Ice Maker not making ice-cover-2198633-00816086.jpg
  6. The Following User Says Thank You to rickgburton For This Useful Post:
  7. #5
    Jan 2012
    That is good news, sounds relatively cheap. Thanks for all your help!
  8. #6
    Jul 2006
    You're welcome!
  9. #7
    JetsetJoey is offline Member
    Nov 2010
    Tacoma
    Default Whirlpool Gold GS6NBEXRL00 Won't Make Ice
    Quote Originally Posted by rickgburton View Post
    You're welcome!
    Hello~
    like the O.P., my same model refrigerator Whirlpool Gold #GS6NBEXRL00 is doing the same thing- not making ice. It was working fine & then just suddenly stopped producing it. When I open the door, the light blinks twice rapidly with a delay. When I hold the little flapper door (with a hole in it), the light goes solid. The little flapper door seems to function fine, as it opens & closes fluidly. If I close the door light switch, the light goes out with flapper door open or closed. Is this relevant? I would appreciate any input.
    Thanks~ Joey
  10. #8
    Jul 2006
    First look at the fill tube going into the ice maker and see if it’s blocked with ice. If it’s not blocked then you’ll need to determine if the ice maker is working by either filling it with water and see if it dumps the ice cubes or force cycle the ice maker.
    FORCE CYCLE
    To force cycle the ice-maker, remove the cover over the module and locate holes “T” and “H”. Take a small piece of wire bent in the shape of a U and short “T” and “H” together. The ice-maker will start the harvest cycle. Wait about 10 seconds and remove wire. The Ice maker will continue through the cycle. At the end of the harvest cycle the ice-maker supplies the coil on the water valve with 110 VAC.
    NOTE: If your refrigerator uses the Optics, you’ll also have to tape the emitter flap back and not block the space between the emitter and receiver. You will also need to hold the light switch in until the ice maker starts then remove the wire. Close the freezer door
  11. #9
    Nov 2010
    Tacoma
    Default Okay, what next?
    FORCE CYCLE
    As I outlined, when you open the freezer door, the light bleeps twice rapidly followed with a delay. When I hold the flapper door (with the hole in it) closed, the light glows solid. If I hold the freezer light switch closed, the light extinguishes. SO THEN, I followed your instructions about forcing a Harvest Cycle by shorting out the "T & H" connectors... & NOTHING (yes I taped the emitter flap back & held the light switch).
    Okay, what next???
    Thanks~ Joey
  12. #10
    Jul 2006
  1. Whirlpool GS6NBEXRL00 Ice Maker Not Working
    By Pmbpatbev in forum Whirlpool/Roper/Estate
    Last Post: April 27th, 2011, 11:13 AM
  2. [FIXED] Whirlpool gs6nbexrl00 Ice maker
    By CONCEDE in forum Whirlpool/Roper/Estate
    Last Post: March 14th, 2011, 02:27 PM
  3. whirlpool gold ice maker leaking
    By widebody999 in forum Whirlpool/Roper/Estate
    Last Post: October 16th, 2009, 08:17 PM
  4. Whirlpool GS6NBEXRL00 Ice Dispenser problem
    By davidlduval in forum Whirlpool/Roper/Estate
    Last Post: February 13th, 2008, 09:16 AM
  5. Replies: 2
    Last Post: July 8th, 2007, 09:56 AM
