Results 1 to 6 of 6
Thread: whirlpool fridge
    getterdone is offline Member
    Jan 2012
    hanover park, illinois
    Default whirlpool fridge
    Model Number: ed25pqxdn01
    Age: More than 10 years
    My Whirlpool fridge will sometimes run by itself and other times I have to tap on the "control box" in order to get it to run. Other times, tapping on it doesn't work at all so I have to turn the tiny slotted dial which seems like a timer using a screwdriver. When it does run it does cool properly in both the freezer and fride. It's getting it to start all on it's own that's the problem. What could be wrong with it? Thermostat? Timer module? Help! Thanks...
    Oct 2004
    Could be either/or/both....I'd change out both and be done with it.
    whirlpool fridge-defrost-timer-482493-00928706.jpg Defrost timer kit, 8 hour, replaces most/instructions included Manufacturer part number 482493
    whirlpool fridge-temperature-control-2198202-00632606.jpg Refrigerator/freezer thermostat Manufacturer part number 2198202
    Neither are very expensive
    Jan 2012
    Thank you Jeff, I will order both parts and I'm positive this will solve the issue.
    Oct 2004
    Your welcome.....me too!
    jeremyflint is offline Member
    Feb 2012
    Birmingham, AL, USA
    Did this fix your issue? my 10 year old Roper is doing the same thing.
    Oct 2004
    Quote Originally Posted by jeremyflint View Post
    Model#?
    LINK> Where is my model#, I need a part, where should I look for my model number Some model# helps.
  1. Whirlpool fridge does not dispense h2o
    By poster54 in forum Whirlpool/Roper/Estate
    Last Post: May 30th, 2011, 12:10 PM
  2. Replies: 10
    Last Post: July 2nd, 2009, 09:50 AM
  3. Whirlpool Fridge
    By Tagman886 in forum Whirlpool/Roper/Estate
    Last Post: December 3rd, 2008, 11:37 PM
  4. Whirlpool Fridge \ Freezer cold Fridge warm
    By Harrison in forum Whirlpool/Roper/Estate
    Last Post: December 6th, 2007, 11:45 PM
  5. Whirlpool ET 21 PK Fridge
    By Bri Fly in forum Whirlpool/Roper/Estate
    Last Post: August 28th, 2005, 07:51 PM
