Results 1 to 6 of 6
Thread: Whirlpool side by side fridge water taste bad
    silverstreak is offline Member
    Feb 2012
    Ocala Florida
    Default Whirlpool side by side fridge water taste bad
    Model Number: ED5VHEXUB03
    Hello, This is my first posting and I need some help. My Whirlpool side by side has had a very bad taste in the water since new. The ice seems to taste just fine. I have replaced 4 filters in the past year and still the water taste like some sort of chemical. I have replaced the supply tube from the water source 3 times and still the same. I have tasted the water at the source and it taste just fine. I have had a technician come out and tell me that he could replace the water storage bin for $300.00 dollars but that if I just keep using the water it will eventually taste ok. This is not happening. Whirlpool will not do anything about this problem and I am very frustrated. Any ideas. I bought this fridge in November of 2010 so the warranty is over. (nice of whirlpool to point this out and not want to help...!!!)
    Oct 2004
    Sounds a little high!
    Whirlpool side by side fridge water taste bad-picunavailable417.jpg Reservoir Manufacturer Number 2307107
    Whirlpool will not do anything about this problem. I bought this fridge in November of 2010 so the warranty is over. (nice of whirlpool to point this out and not want to help...!!!)
    They have grown too big and are one of the worst companies to deal with any more!...JMO!
    That often happens.
    Hopefully the water tank/reservoir will help.
    http://www.applianceaid.com/
    NEW Appliance Repair Aid
    http://www.jrappliance.ca
    JRAppliance
    Feb 2012
    Ocala Florida
    Thanks Jeff1, Is this something I can do myself or do I need to hire a technician?
    Feb 2012
    Ocala Florida
    Thanks Jeff, is this something I can do myself or do I need to hire a technician?
    4arepair's Avatar
    4arepair is offline Member
    Dec 2011
    Austin, TX
    The line you are using to connect the refrigerator to the incoming water outlet may be the culprit. White vinyl, blue vinyl and stainless jacketed inlet hoses will impart a bad taste quite often. Try replacing it with this hose. I've had great results using this approach... http://www.repairclinic.com/PartDeta...8X10006/880514
    Oct 2004
    Quote Originally Posted by silverstreak View Post
    Not overly difficult...we don't know your capabilities but it is not rocket science!
    Copper water line to the refrigerator is best...JMO!
    JRAppliance
