June 26th, 2012, 11:17 AM
Ice make will not work
I have a whirlpool gold series conquest side by side indoor ice maker .. It stoped producing ice .. As far as I know the line isn't clogged .. I've taken the maker itself out and there was ice in the bottom of it like it started to make ice but stoped what shoul I do now ??
June 26th, 2012, 11:19 AM
I need your model number to look it up. Read it from the tag on the machine: Help Me Find My Model Number - RepairClinic.com
OWNER RICK'S APPLIANCE REPAIR
REFRIGERATION SPECIALIST
June 26th, 2012, 11:31 AM
June 26th, 2012, 11:46 AM
Let's start by checking the optics. Open the freezer door and check the status LED. 2 Blinks followed by a 1 second delay-repeated: Tape the emitter door back so it doesn’t block the beam between the emitter and receiver. LED is on steady: Optics good. 2 Blinks followed by a 1 second delay: Bad optics Part# 4389102 (Ice Level Control Board 4389102 Order now for same day shipping. 365 day return policy. RepairClinic.com)
June 26th, 2012, 11:57 AM
June 26th, 2012, 12:43 PM
OK let's see if it will force cycle. To force cycle the ice-maker, remove the cover over the module and locate holes “T” and “H”. Take a small piece of wire bent in the shape of a U and short “T” and “H” together. The ice-maker will start the harvest cycle. Wait about 10 seconds and remove wire. The Ice maker will continue through the cycle. At the end of the harvest cycle the ice-maker supplies the coil on the water valve with 110 VAC.
NOTE: If your refrigerator uses the Optics, you’ll also have to tape the emitter flap back and not block the space between the emitter and receiver. You will also need to hold the light switch in until the ice maker starts then remove the wire. Close the freezer door
June 26th, 2012, 01:10 PM
Ok I used a paper clip .. Pushed it In as far as it would .. The optics were not blocked and the light off .. I waited ten seconds ... Nothing happened ...
June 26th, 2012, 01:33 PM
June 26th, 2012, 04:07 PM
Ok thank you for your help .. Hope a new one helps
June 26th, 2012, 08:05 PM
By cheapthrill in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: March 5th, 2012, 05:10 PM
By BS67 in forum Whirlpool/KitchenAid
Last Post: February 18th, 2012, 10:55 AM
By garshok in forum GE/Hotpoint
Last Post: February 17th, 2012, 06:32 PM
By jimyoungblood in forum Sears Kenmore
Last Post: July 12th, 2011, 12:38 PM
By Aahhyes68 in forum Frigidaire/Electrolux
Last Post: December 3rd, 2007, 05:17 PM
