May 13th, 2006, 08:19 AM
flapper door fell down
Whirlpool ED25TQXFW00
Thru-door ice dispenser
Plastic tab broken on main housing (11 1/8 wide plastic box). This tab holds the right side of the metal axle of the flapper door assy. The flapper door assy had fallen down.
The main housing is item#1 on this drawing:
http://www.applianceaid.com/image/wp...re-dispens.jpg
1. Is there any kind of repair kit to cut off tab and screw or glue an axle holder for the flapper door?
2. I cant find the item #1 in the appliance blog parts area. (it did seem to recognize my model number). Is it avialable and how much?
3. Any suggestions for my own "screw and glue" repair?
4. (Just curious) There is a flex circuit board with two conductors going to the flapper door. What type of sensor is in the door? And what is it for.
May 13th, 2006, 04:23 PM
They don't make the main dispenser housing anymore on your model.
I remember when they used to make it, it was a nightmare to install.
I not sure what to tell you on gluing it. Maybe someone who has successfully done the gluing can help you with it.
May 13th, 2006, 07:02 PM
repair kit avialable
Found out on another forum a repair kit is avialable.
Quote below
An ice chute door hinge tab repair kit is available, part
number 8201756. This repair process and kit can be used
for all dispenser housings on Whirlpool built SxS
refrigerators or KitchenAid built-in refrigerators from 1997
to present. Follow the instructions provided with the kit.
R8178548
November 2005
All dispenser model SxS refrigerators with serial codes SR36 to SS27 and KitchenAid built-in
refrigerators with serial codes QR31 to QS41
May 13th, 2006, 11:22 PM
That's good news, I wasn't aware of that kit, thanks for letting us know about it.
August 21st, 2010, 05:33 PM
Review after 4 years use!
After using this repair kit for over 4 years, I had a problem with it but did a couple of mods to fix it. If you are going to install it, I would recommend the mods described below be done up-front.
ALSO: The install instructions and more info are posted on another forum. See:
flapper door fell down - The Kitchen Appliance Repair Forum - Do-It-Yourself Appliance Repair Help - ApplianceGuru.com: The Samurai Appliance Repair Forums
I installed the kit in 2006 and it worked till recently, when the axle (just a nail) slipped and let the door fall open. I put it back and that lasted only a week before it slipped again. The 2nd time, I also noted the adhesive for the metal bracket (double sided sticky foam) was starting to let go on one end, contributing to the movement of the axle every time ice is dispensed.
So – I would recommend the following mods immediately if you install it:
- Make sure the axle (nail) is captured at the free end so it will not work itself out. I filed a groove in the nail and installed a tiny C clip (from my junkbox) to keep it from coming out again. A dab of glue might suffice but that solution has its own problems.
- Figure out some way to attach the metal bracket other than just the adhesive tape. I just carefully drilled a hole in one end while the bracket was in place – limited depth – then drilled the bracket only with a slightly larger bit and put a self-tapping screw in the plastic. Its holding so far. (several weeks)
Maybe epoxy or Plumbers Goop would hold if applied liberally. This would be messy and you have to figure out some way to hold it (tape?) till the glue cures. But If you have the tools and are brave, I recommend just drilling two holes in either end of the bracket and installing with two self-tapping screws into the refrigerator door plastic. Find two SHORT self-tapping screws (approx 1/8” diameter - NO more than ˝” long ) and a matching drill bit SMALLER than the outer thread diameter of the screws. Place the bracket carefully, mark for holes in the bracket, drill them. This hole is to obviously be larger than the selected screws (You will need a good drill bit as the bracket is tough steel). Then place it again and mark the door plastic for holes. CAREFULLY drill limited-depth holes (DON’T go completely thru the door! ONLY to depth needed for the screws you have). Install the self tapping screws – not too tight –remember its fairly thin plastic.
Good Luck!
August 21st, 2010, 11:53 PM
Thanks evofxdwg for the update and the added information to help others.
By turbospeed in forum GE/Hotpoint
Last Post: July 28th, 2007, 09:03 AM
By jimbo63 in forum GE/Hotpoint
Last Post: August 4th, 2006, 10:07 AM
By bfollett in forum GE/Hotpoint
Last Post: July 4th, 2006, 08:37 AM
By reding93 in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: June 12th, 2006, 01:05 PM
By vk-30 in forum Whirlpool/Roper/Estate
Last Post: June 7th, 2006, 11:29 PM
