Results 1 to 4 of 4
Thread: Water Dispenser Tubing has "green film"
    FourMcGrews is offline Member
    May 2006
    North Carolina
    Question Water Dispenser Tubing has "green film"
    Hello,
    The tubing coming out from the frig to the water dispenser has developed a green "film" inside. I was able to clean the very end of the tubing, but can't get further back. Plus, I'm wondering if this green stuff is throughout the whole line.
    Is there any way to clean/flush out the line to, I guess disinfect it? I'm hoping I don't need to have a tech come out and pay 100's of dollars to replace the tubing.
    Any suggestions?
    Cheryl
    It would be very difficult to clean it internally, replacing it is the best way, whats the model#?
    May 2006
    North Carolina
    Default Green film problem
    Thanks, Jake, for your reply.
    It's a Whirlpool Gold, Model # GD5SHAXKB00.
    Is this something we could actually replace ourselves? Or, should we really leave it to a professional. Don't want to make things worse!
    Cheryl
    Its really not that hard to change, You have a connector behind your bottom kick-plate, it comes undone there, then the upper part is in the front dispenser, the plastic water line with that little metal support piece on it. That front trim around your dispenser has 2 small slots underneath the bottom part of the dispenser frame, that pops off with a flathead screwdriver.
    Here is the part you need:
    Fitting and tube assembly, water dispenser
  1. Water Dispenser SDX26VL
    By jxp_app in forum Amana
    Last Post: February 8th, 2007, 10:49 AM
  2. Kenmore refrigerator water dispenser drips
  3. Whirlpool Gold water drip from dispenser
    By wiznkids in forum Whirlpool/Roper/Estate
    Last Post: November 30th, 2006, 09:31 AM
  4. Frigidaire SxS water dispenser is dripping water
    By batman in forum Frigidaire/Electrolux
    Last Post: June 13th, 2006, 11:15 AM
  5. Replies: 9
    Last Post: January 2nd, 2006, 09:22 AM
