June 18th, 2006, 07:26 PM
Another Whirlpool Icemaker Problem
My modular icemaker (IM#51062198597) had ice freeze up and stop the ice dispenser. I eventually heard it clicking trying to turn the dispenser. I removed the ice and hooked the icemaker back up. Nothing was working. Took the icemaker back out and found one of the plastic prongs on the drive broken allowing the dispenser fingers to freely turn. Can I purchase only the small plastic sleeve with the prongs that attach the exterior dial?
Also, I would have thought with just this mechanism broken that the icemaker would still fill with water, but it is not. With the dial not attached properly, the conection is broken from the dial to the icemaker motor itself. Will this disconnect cause the icemaker not to fill with water. Just wondering if the broken "pronged coupling" is my only problem.
Any information would be appreciated.
June 18th, 2006, 11:53 PM
I could get you a parts diagram, but we will need your refrigerator model#.
June 19th, 2006, 06:20 PM
Refrigerator is a Whirlpool Gold Model # GD5YHAXNL00.
June 20th, 2006, 09:36 AM
Here is the parts diagram for your ice dispenser:
http://www3.sears.com/imaging/ImageP...&titleID=00005
#16 is the coupling
#25 is the coupling, bottom
Over the years, I have had to replace more of these than anything else.
June 20th, 2006, 06:57 PM
I am sorry but I must have used the wrong terminology. The "dispenser" I was referring to is the fingers that rotate and kick the ice out of the icemaker. The parts that are broken are inside the icemaker. I found what appears to be the diagram, but it does not seem to list the parts that I need. I need the dial (has "Do not rotate manually" written on it), and the "coupling that locks the dial into place (round hollow cylinder with two pinch fingers that lock into the dial.
I am wondering if these parts are sold seperately or do I have to purchase the entire assembly (around $75).
I am also still curious to if the dial being disconnected (with it broken it does not make proper contact (brass terminals no longer touch housing properly) should the water still be dispensed into the cube tray?
June 21st, 2006, 09:11 AM
Ok, sorry about that.
Here is the parts diagram for the ice maker:
http://www3.sears.com/imaging/ImageP...&titleID=00012
#35 is the front module assembly
Its possible for that dial to be broken but still put water in, I would just turn off the ice maker till you fix it.
By chatparle in forum Whirlpool/KitchenAid/Roper/Estate
Last Post: January 29th, 2007, 12:29 PM
By melbosch in forum Whirlpool/Roper/Estate
Last Post: January 9th, 2007, 07:24 AM
By dodie53 in forum Whirlpool/Roper/Estate
Last Post: December 8th, 2006, 09:30 PM
By ticemaker in forum Whirlpool/Roper/Estate
Last Post: October 14th, 2006, 10:54 AM
By appliancejunkie in forum Whirlpool/KitchenAid/Roper/Estate
Last Post: October 1st, 2006, 10:56 AM
