June 29th, 2006, 03:07 AM
Conquest not making ice
I have a Conquest side-by-side model GS6SHAXMS00, mfg date 09/03. It stopped making ice but it was a week before I noticed. The arm was stuck in the 6:00 position frozen in half size ice cubes. I got the hairdryer, melted it and cleaned everything out. I rotated the arm to the 2:00 position as stated in the posts that I found. Unplugged the refrigerator for 3 minutes to reset. Held down the left flap and the light switch for a couple minutes but never heard any motor sounds. The LED blinks when I have the door open. Stays on when I hold down the left flap and goes out when I hold the light switch. It's been a week now and still no movement or ice.
What is my next step? Is the board bad?
Thanks in advance for your help.
June 29th, 2006, 09:52 AM
How did you rotate the arm to the 2:00 position?
Your board could be bad, or the gear on your ice maker is broken. That gear should not move freely with your hand.
June 29th, 2006, 12:44 PM
I rotated the "fingers" with my hand. It turned easily. I rotated it until I heard a click and stopped in the 2:00 position. So it sounds like the gears are broken.
Even if the gears are broken, shouldn't I hear something turning? It's been completely silent. What part will I need to order?
How do I check if the board is bad?
Would any of this be under warranty? I've had the refrigerator for 2 1/2 years. Got it brand new with the house from the builder so I have no receipt or proof of purchase.
June 29th, 2006, 04:09 PM
Yes, sounds like your gear is stripped, you shouldn't have been able to move the ejector blades with your hand.
Here is the module assembly for your model:
Icemaker control module kit
No, your warranty is only for 1 yr. except on the sealed system, which is 5 yrs.
Your board should be fine.
June 29th, 2006, 05:57 PM
Thanks Jake. I ordered the part. I hope it's not hard to install.
June 30th, 2006, 10:33 AM
Its fairly easy to install.
July 5th, 2006, 05:15 PM
OK. I replaced the module. The white plastic piece was broken. I unplugged the refrigerator for 2 minutes. Held in the left flap and light switch for 2 minutes and nothing happened. No sounds.
When I open the door the LED flashes 2 times, then 1 second pause.
Stays on when I hold the left flap.
Goes off when I hold the light switch.
What does that mean? Don't tell me I have a bad sensor board.
July 5th, 2006, 05:55 PM
Remember when they said patience is a virtue ... well it seems the fingers slowly rotated when I wasn't paying attention. The water filled the tray when they got to the 10:00 position and now they are resting in the 2:00 position.
Now comes the hard part ...waiting for the water to freeze. It looks like I'm on the way to getting my first harvest but I won't know until morning.
July 6th, 2006, 09:31 AM
Yes, it takes time.
Hopefully you got it fixed, it sounds like it.
August 6th, 2006, 05:49 AM
Conquest doing same thing
I have had my conquest for 13 months now. The Icemaker stopped once before, and I took out the filter, replaced it, and all went back to normal.
It has recently stopped working again, and tried the same trick...no such luck.
I have been reading these blogs about the ejector arm position. I am looking at mine, and the water spout is on the right side. From this side, it appears my arms are in the 8' O clock position, as if they were pointing at my chest.
Is there a way to move these arms, without using my hands? Otherwords, is there some button I can push to make the ice machine cycle?
This is really frustrating! I bought this fridge/freezer the same time I bought the whirpool duet washer & dryer. I have already had problems with the washer, now this! Does Whirlpool not make good products anymore??
By jamiedolan in forum GE/Hotpoint
Last Post: April 30th, 2007, 11:29 AM
By Euro-Tour in forum Whirlpool/Roper/Estate
Last Post: March 14th, 2007, 09:28 PM
By ysp in forum Whirlpool/Roper/Estate
Last Post: December 7th, 2006, 05:30 PM
By Axalotaqs in forum Amana
Last Post: November 3rd, 2006, 12:45 AM
By regmo0513 in forum GE/Hotpoint
Last Post: August 11th, 2005, 04:24 AM
