Results 1 to 3 of 3
Thread: Ice maker slowly trying to make ice(bulletin)
    tolbertr is offline Member
    Apr 2007
    Houston, TX
    Default Ice maker slowly trying to make ice(bulletin)
    The fridge model is ED5NHGXRQ00. The ice maker stopped making ice almost completely. After the mold fills with water, the rake is at about 2 o'clock. At some point, the ice warms and the rake comes down to about 4 o'clock. The rake ends up freezing within the ice. Eventually (another warming period maybe) the rake gets the ice out of the mold; however, given the rake was frozen within the ice, the ice never gets completely dumped for the cycle to start again. The ice and rake end up at about 2 o'clock, and I have to grab the ice of the top of the rake. This weird cycle then starts again.
    Yes, I found a bulletin on this issue:
    https://secured.whirlpool.com/Servic...LE/8178359.pdf
    You will need to order this ice maker module kit:
    Part#8201515
    Icemaker control module kit
    alexloramer is offline Member
    Sep 2010
    Indianapolis IN
    Yeah I find that with fridges the ice machine is often the 1st thing to go. I'm not sure why. Maybe all the changing temperatures in it affects things.
    I'm only for stainless steel appliances. Anything else will fade with time and not look as good.
  1. [FIXED] Kenmore Coldspot Ice Maker Stopped Working
    Last Post: October 23rd, 2011, 10:34 AM
  2. frigidaire ice maker leak
    By icemanTO in forum Frigidaire/Electrolux
    Last Post: September 28th, 2008, 06:25 PM
  3. Whirlpool ice maker water fill tube and cup freezing up
    Last Post: July 26th, 2007, 11:23 PM
  4. Ice maker supply ice dam?
    By mlamourine in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: May 23rd, 2007, 10:46 PM
  5. Unique Ice Maker Leak
    By gammonej in forum Sears Kenmore
    Last Post: April 8th, 2007, 11:43 PM
