Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 79
Like Tree1Likes
Thread: Water dispenser problem
  1. #11
    Ok, sounds good.
    Fergs is offline Member
    Apr 2007
    Michigan
    I installed the new water inlet valve this afternoon and everything is working. The new valve had push on connectors which work really nicely. Thank you again for all of your help.
  3. #13
    Excellent Fergs, glad the new water inlet valve fixed it for you.
    Apr 2007
    Michigan
    On a related note, During the removal of the inlet valve I must have disturbed the connections at the water filter as I found a small leak was dripping into the drain pan. I removed the water filter housing and cut 1/4" of the end of the lines but couldn't stop the leak. I found that the O rings were deteriorating (probably 8+ years old) and after doing a search here, it appears that there is no replacement kit and you have to replace the housing itself. So, I just purchased a new housing and filter element from a local supplier during lunchtime. Pretty sure that should take care of it but any further advice is always appreciated.
  5. #15
    Yes, I've had to replace my share of those water filter housings as well for the same leak issue.
    Here's the filter housing for your model, in case others with your model need to order it:
    Manufacturer's Number: 2186443
    2186443
    Apr 2007
    Michigan
    Thanks Jake, I have it installed with a new filter, no leaks. I noticed right away how much tighter the O-ring connections were with the new housing.
  7. #17
    Sounds good Fergs.
    vellankis is offline Member
    Mar 2011
    Aldie, VA
    Default WPL Water not coming from Dispenser
    Hello Jake
    As per your suggestion i have changed the water inlet valve at the back of the Refrigerator assuming that might be problem, however i am still not able to get the water from the dispenser. Pls help
  9. #19
    Whats the model# of your refrigerator?
    Help Me Find My Model Number - RepairClinic.com
    Your water tank is in the bottom of your refrigerator section may have frozen causing this, its behind your crisper's. Get a hair dryer and warm it up.
    When you push the water dispenser lever do you hear any sound at all coming from the water inlet valve in the back of your refrigerator?
    Mar 2011
    Aldie, VA
    Model # ED5FHAXVS01
    Yes there is a sound coming from the water valve in the back when dispenser is pushed. Shall try to cool the water tank and post the results.
  1. Another GE Water/Ice Dispenser Problem
    By billp44ruby in forum GE/Hotpoint
    Last Post: March 20th, 2011, 12:08 PM
  2. Water dispenser problem
    By ayreonman in forum Amana
    Last Post: June 3rd, 2010, 11:18 PM
  3. water dispenser problem
    By svrao in forum Frigidaire/Electrolux
    Last Post: November 9th, 2008, 03:27 PM
  4. Another Water dispenser problem
    By RoryC in forum Frigidaire/Electrolux
    Last Post: August 16th, 2006, 09:11 AM
  5. Water Dispenser problem
    By sampitroda in forum Amana
    Last Post: December 22nd, 2005, 03:00 PM
