Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 62
Thread: [FIXED] Water dispenser problem
  1. #41
    jasper is offline Member
    Jan 2011
    Minnesota
    Thanks for your expertise once again Jake ! I just put a donation in the "tip" jar :-)
  2. #42
    Thanks jasper, glad to help.
  3. #43
    MLC05 is offline Member
    Jan 2012
    Texas
    I have a Kenmore Elite model 106.57703701 that the water dispenser stopped working all of a sudden. It makes an audible click on the lower side of the fridge when the dispenser button is pressed. Any ideas?
  4. #44
    Is the ice maker still making ice and getting water to fill it?
    Pull your refrigerator out from the wall, then remove the lower back access panel, then unmount the water inlet valve where your water supply line connects to, then remove the larger diameter plastic water tubing under the valve, then get something to catch water in and put it under the valve, then have someone press the water dispenser lever and see if water comes out of that valve directly.
    If no water comes out then its a bad valve.
    Here's the water inlet valve for your model you can order here if needed:
    Manufacturer part number W10159839 is RepairClinic item number 1389142
  5. #45
    Jan 2012
    Texas
    Default Jake, Finally got to check water inlet valve... Please advise
    Ice maker is still making ice....
    Water did not come out of the water inlet valve when I disconected the larger diameter plastic tubing and had my wife press the water dispenser button....does this mean it is a bad water inlet valve even though it is still making ice?
    MLC05
    Quote Originally Posted by MLC05 View Post
    MLC05
    Yup, thats correct.
  7. The Following User Says Thank You to Jake For This Useful Post:
    MLC05 (February 17th, 2012)
  8. #47
    G&O
    G&O is offline Member
    May 2011
    Pacific Northwest
    Jake!
    You hooked me up a few years ago with this exact problem and now I have it again.
    (Different fridge, same model - Whirlpool ED20DFXEB01)
    The problem - the unit makes ice as normal but dispenses no water. The part I replaced before looks just like the blue valve in the pics here. Got a part number for me?
    And, I think my neighbor has the same problem. Condos, so we have the same appliances but I'll confirm her model number and get back to you in a follow up if I need to. Otherwise, I think we'll be ordering two of them...
  9. #48
    Ok,
    Manufacturer's Number: W10245167
  10. #49
    Jan 2012
    Texas
    Got the inlet valve in and working like a champ again...Thanks Jake!
  11. #50
    Excellent, glad to hear that.
  1. September 5th, 2009, 01:44 PM
  1. GE Profile Arctica Water dispenser problem
    By alian in forum GE/Hotpoint
    Last Post: January 18th, 2012, 12:29 PM
  2. Water Dispenser SDX26VL
    By jxp_app in forum Amana
    Last Post: February 8th, 2007, 09:49 AM
  3. Frigidaire Door Water Dispenser Leak
    By rsmbud in forum Frigidaire/Electrolux
    Last Post: September 11th, 2006, 08:16 AM
  4. Jenn-Air JCD2289ATB water dispenser quit after middle of night "flood"
    By aweyhau in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: September 9th, 2006, 11:42 AM
  5. Another Water Dispenser Problem
    By fst in forum Frigidaire/Electrolux
    Last Post: July 29th, 2006, 11:14 PM
