Page 1 of 7 123 ... LastLast
Results 1 to 10 of 62
Thread: [FIXED] Water dispenser problem
    Fergs is offline Member
    Apr 2007
    Michigan
    Default [FIXED] Water dispenser problem
    Model Number: ED22RFXFN01
    Whirlpool Ultraease side by side, model ED22RFXFN01. The water dispenser started to slow down and now no longer dispenses water. We replaced the water filter but the problem persists. The ice maker works with no problems. What should I look for? Thanks!
    Heres the parts diagram for your model:
    ED22RFXFN01
    Diagram#7 part location#10 is your inlet water valve thats on the back of your refrigerator when your refrigerator out from the wall.
    Unmount that part and then take off the plastic tubing underneath it that goes to your water dispenser, its usually the larger of the 2 plastic water lines, then get a container to put underneath your water inlet valve, then have someone press the water dispenser lever in front, if no water comes out, then your water inlet valve is bad.
    Apr 2007
    Michigan
    Thanks a lot. I will check that out. Much appreciated
    Glad to help Fergs.
    Let us know the outcome.
    beltouche is offline Member
    Jun 2007
    Danville, VA
    Thumbs down Similar water dispenser problem
    Whirlpool model # ED5GHGXMQ00
    The water dispenser just stopped dead at some point. The ice maker continues to function properly. From looking at previous posts it seems that most people have at least a hum indicating that the pump is operating; I have no hum.
    I'm wondering if this might be a bad switch rather than a water inlet problem. That might be "preferrable", as the frig is set in a cabinet and would be a pain to pull away from the wall. How can I check for a problem "up front" behind the dispenser panel first?
    This sounds like you have a broken dispenser bracket, this thread explains it all, and has the part you can order in it:
    http://www.applianceblog.com/mainforums/showthread.php?t=7349
    Jun 2007
    Danville, VA
    Thumbs up That's it!
    You hit the nail right on the head! As soon as I popped off the outer cover (BTW, for anyone reading - don't stick the screwdriver too far inside. It's actually a shallow retainer. If you go too deeply, you're tugging on the bracket itself, which makes it seem harder than it is.) a plastic pin fell out. A second was held on only by a hair. I've taped the switch (#14) & the ¿spacer? (#24) to the main plate (#15) which is what needs to be replaced.
    Thanks for the help.
    Apr 2007
    Michigan
    It has been awhile! Since the ice maker always worked on our Ultraease ED22RFXFN01 we put off the repair to the water dispenser. However this weekend water suddenly started flowing freely from the water dispenser. Unplugging the fridge didn't help, I had to shut off the water supply. When you push the paddle on the front you can hear a hum which has me thinking that the solenoid on the inlet water valve # 10 in diagram 7 is stuck open. Am I on the right track with this? It is $87.47 + tax so I wanted to make sure before buying.
    Yes, sounds like your water inlet valve is bad.
    I found it for $54 here:
    Manufacturer's Number: 4389177
    4389177
  10. The Following 2 Users Say Thank You to Jake For This Useful Post:
    Fergs (August 11th, 2009)
  11. #10
    Apr 2007
    Michigan
    Thank you, I just placed the order from your reference. I will be sure to post the results.
  1. September 5th, 2009, 01:44 PM
  1. GE Profile Arctica Water dispenser problem
    By alian in forum GE/Hotpoint
    Last Post: January 18th, 2012, 12:29 PM
  2. Water Dispenser SDX26VL
    By jxp_app in forum Amana
    Last Post: February 8th, 2007, 09:49 AM
  3. Frigidaire Door Water Dispenser Leak
    By rsmbud in forum Frigidaire/Electrolux
    Last Post: September 11th, 2006, 08:16 AM
  4. Jenn-Air JCD2289ATB water dispenser quit after middle of night "flood"
    By aweyhau in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: September 9th, 2006, 11:42 AM
  5. Another Water Dispenser Problem
    By fst in forum Frigidaire/Electrolux
    Last Post: July 29th, 2006, 11:14 PM
