November 12th, 2007, 08:51 PM
November 13th, 2007, 12:04 AM
Whats the model# of your oven? Its located inside the door or on the bottom frame.
November 13th, 2007, 07:56 AM
HI ~ thank you I didn't know where to look last night...it is model # 9752834a
November 13th, 2007, 12:16 PM
SORRY wrong numbers...here is the model number: gw395legq3
I am hoping to fix this soon, any help would be wonderful.
November 13th, 2007, 08:59 PM
Here's the service sheet for your model:
http://www.servicematters.com/docs/w...%209753053.pdf
I don't see a E2 F3 on the list, I see F3 E2.
F3 E2
Bake range over
temp
1. Measure sensor value (between connector pins) between 1000
Ω @ 32° F (0° C)
and 2697 Ω @ 900° F (482° C) (approximately 1080 Ω @ room temperature). If
measurement does not correlate to real temperature, disconnect power,
replace sensor and refer to steps 3-5. Also measure from sensor connector to
sensor casing for possible short.
2. Trace wires and connectors to sensor, from control, then from sensor back to
control. If all connections made and no wire damage, refer to step 3.
3. Disconnect power for longer than 30 seconds.
4. Reapply power and observe for longer than 1 minute.
5. If failure remains, disconnect power, replace control, then go back to step 4.
November 13th, 2007, 11:04 PM
I know, thank you....however the E2 is first then F3 and like I said before it will go off even if we haven't cooked...like at 1:30am I am so confused on where to go for help. We have found nothing about this situation.
November 14th, 2007, 12:39 AM
Ok, I'm not sure then, you may have to contact Whirlpool to send a tech. out on yours.
