Results 1 to 6 of 6
Thread: [FIXED] Super Capacity 465 model SF315PEGW5 oven not functioning
    Mav1972 is offline Premium Member
    Jul 2008
    Struthers, OH
    Default [FIXED] Super Capacity 465 model SF315PEGW5 oven not functioning
    It all started after I purchased a house and found that the oven does not work. The stove top is perfect and all igniter's work along with a flow of gas. The control panel appears to be fine, and when I selected the bake option, the preheat/Start display flashes. But no heat. I do get a PF error after unplugging the unit, but this appears to be normal indicating a "Power Failure". So looking into the broiler part, I couldn't see that the igniter was glowing. Ok, so I bought a new igniter without first testing the volts. The new igniter came the other day, put it in, and still nothing. Thanks to the internet, I found this site, and started to troubleshoot with only a volts meter. Testing the power, I'm only getting a few volts out of the wires to the igniter. So the igniter is good, but no power. I cannot see any type of fuse to replace and all the wires look good. I have looked at some link you supplied for troubleshooting, but I'm not sure on how to test the OHM's thing. I guess if I understood, I could determine if it is the gas valve " as indicated in other forums" before I go out and drop over a hundred dollars.. Any help would be greatly appreciated.>>
    You'll need a new electronic clock/oven control board.
    Here's the cheapest one I found for your model:
    Manufacturer part#6610152 is RepairClinic item#675669
    6610152
    Jul 2008
    Struthers, OH
    Thanks for your help.. I ordered a new one today, and should have it by next week. Hope this helps.
    Sounds good Mav,
    Let us know the outcome.
    Jul 2008
    Struthers, OH
    Thanks Jake, that did the trick.. The "start" button was bad on the old control board.
    Again, thanks for all your help.
    Excellent Mav, good job fixing it.
  1. WhirlPool super capacity 465 oven not working. Repair Manual
    By JSPerdomo in forum Whirlpool/Roper
    Last Post: December 16th, 2012, 10:38 AM
  2. Whirlpool Super Capacity 465 / Gas Oven
    By jeff_465 in forum Whirlpool/Roper
    Last Post: November 25th, 2007, 01:26 AM
  3. Replies: 1
    Last Post: July 2nd, 2007, 04:43 PM
  4. Whirlpool super capacity 465 gas oven not lighting
  5. Replies: 1
    Last Post: September 29th, 2006, 10:41 AM
