August 29th, 2010, 05:01 AM
#11
oven door won't open after cleaning
I had/have the same problem with my electric Whirlpool Super Capacity 465. After this last cleaning, I had to throw the breaker and wait until the oven cooled down. When I threw the breaker back on, the door opened. What's with these appliances?
November 19th, 2010, 11:51 AM
#12
Will it work without a motor?
Hey Jake thanks for the info. Im having the same problem. Getting info before I start anything. Access through the back right? Any idea if the oven will work without a motor for the lock latch? I'm planning to unlock it and pull the motor out. As long as the door stays shut its all good.
thanks again,
Mike.
November 19th, 2010, 12:23 PM
#13
Hi Mike,
I need a model#
Help Me Find My Model Number - RepairClinic.com
Some you access from the back, some from the top.
Don't remove your lock motor, then you oven wont work at all.
January 1st, 2011, 08:15 PM
#14
Whirlpool- Fun puzzle, lousy oven.
Hello,
I'm new to this too, hope it works.
I've got a Whirlpool Gold oven (Model # GW395LEPS00).
The door locked shut and the display went out after a self-cleaning cycle.
Power to the oven and display panel are fine.
I half disassembled the thing and jimmied the door open but the locking mechanism is still in 'lock' mode.
I couldn't get any help through whirlpool. I'm thinking to replace the display circuit board and the latch assembly.
If anyone has some input it would be greatly appreciated.
Thank you.
January 1st, 2011, 09:54 PM
#15
Yes, sounds like a bad control board causing this issue.
Its fairly easy to replace, you just unplug the range, then take the back console access panel off, should be about 4-6 screws, then you will see it mounted in with about 4 screws.
Just write down on paper where each electrical connector goes, then its exactly the same on the new one.
Here's the control board for your model you can order here:
Manufacturer's Number: 9760013
Here's the door lock assembly you can order:
Manufacturer's Number: W10195934
January 3rd, 2011, 04:50 PM
#16
Whirlpool super 465 autoclean problem
I'm having a similar problem as svernon except after a minute after turning on autoclean fse1 and a beeping happen and I can't open the door now. So part # Manufacturer's Number: W10107830
is locking up the cycle and needs to be replaced. Also the oven light doesn't come on anymore. Thanks fo any help.
January 3rd, 2011, 08:39 PM
#17
Originally Posted by
ssyam69@yahoo.com
Do you have the exact same model# as svernon?
January 3rd, 2011, 08:42 PM
#18
Yes. The model no.ends with q no number after.
January 4th, 2011, 10:25 AM
#19
Ok, so did you already order part # Manufacturer's Number: W10107830 ?
Did you check your oven light bulb to make sure thats not bad itself?
January 4th, 2011, 10:40 AM
#20
No this just happened a couple of days ago so I haven't ordered the part yet and I can't get the door open to check the bulb. I'll order the part tomorrow.
By JSPerdomo in forum Whirlpool/Roper
Last Post: December 16th, 2012, 10:38 AM
By guy43 in forum Whirlpool/Roper
Last Post: February 1st, 2010, 11:31 PM
By jeff_465 in forum Whirlpool/Roper
Last Post: November 25th, 2007, 01:26 AM
By marcum03 in forum Whirlpool/Roper
Last Post: September 29th, 2006, 10:41 AM
