Results 1 to 10 of 14
Thread: WhirlPool Super Capcity 465 doesn't light back burner
    vandeneykel is offline Member
    Dec 2005
    Anaheim CA
    Unhappy WhirlPool Super Capcity 465 doesn't light back burner
    The back burner's "spark plug" is clearly cracked and the spark occurs down near the bottom along the crack rather than at the top, so it rarely ignites on its own.
    What part(s) do I need to replace? What are the part #s?
    Thanks in advance.
    You would need a new spark igniter itself, If you can post the model#, we can help you look-it up.
    Dec 2005
    Anaheim CA
    Default Model #
    Hi Jake,
    The model #is SF385PEGQ 3. Thanks in advance for your help.
    The left rear is part#8053717
    The right rear is part#8053719
    Dec 2005
    Anaheim CA
    Thanks so much for your help.
    Mark
    Glad to help Mark.
    Dec 2005
    Anaheim CA
    Default Question for Jake
    I installed the part and all seems to work OK. I lifted up the surface where the burners sit. After cajoling the burners free from their respective gas output pipes, the lid lifted completely. Fishing the new wire through was tricky but not too bad. After replacing the spark igniter, I simply closed the lid, cajoling the gas output pipes back into the burner assemblies.
    I am surprised that the burners seem to just sit on the gas output pipes with the spring-like seals. My impression is that these wouldn't form much of a seal. Is there anything tricky that I might have overlooked?
    Thanks in advance,
    Mark
    No, it sounds like you did it correctly Mark.
    Thanks for the update.
    Dec 2005
    Anaheim CA
    Smile
    OK, I feel better now.
    Thanks again, Jake.
    Glad to help Mark.
  1. WhirlPool super capacity 465 oven not working. Repair Manual
    By JSPerdomo in forum Whirlpool/Roper
    Last Post: December 16th, 2012, 10:38 AM
  2. Whirlpool Super Capacity 465 Gas Oven failure
    By IanW in forum Whirlpool/Roper
    Last Post: December 16th, 2010, 11:16 AM
  3. Whirlpool super capacity 465 gas oven not lighting
  4. whirlpool 465 oven burner stays on
    By peanut3122 in forum Whirlpool/Roper
    Last Post: January 22nd, 2007, 12:01 AM
  5. Whirlpool Super capcity 465 error
    By soapscarlet in forum Whirlpool/Roper
    Last Post: August 9th, 2006, 08:48 AM
