Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Whirlpool oven error code F3 E2
  1. #11
    mlamont is offline Member
    Jan 2006
    New Castle, PA
    Found the Error code sheet. Attached is the scan of the code page for my model. I've tested the temp sensor... it's OK. Tested the continuity between the sensor plug and the electronic control board... good connection. I unpluged, checked and re-pluged all connectors, plugs and wiring harnesses to ensure good connections and no corrosion. I also pressed and held the cancel button for 5 seconds to have the display show the stored error codes to verify the F3-E2 code. The fault/error code is stored in it's memory. According to the error code what else could be the problem?? Do I bite the bullet and order a new electronic control board? Can the existing board be tested?
    Thanks again!!! for all of your help. Hope I got the attachment right.
    Mike
  2. #12
    Jan 2006
    New Castle, PA
    The error code PDF attachment
    Attached Files Attached Files
  3. #13
    Yes, it sounds like the control board is bad.
    Electronic control board
    Jan 2006
    New Castle, PA
    That's the board. For $145 bucks that thing should cook me dinner too! I'll put the order in, I'm sure that will fix the problem. Thanks again for all the help. This is great forum, lots of good information.
    Mike
  5. #15
    Glad to help Mike, that should take care of it.
  1. whirlpool double wall oven doesn't work
    By Barreras in forum Whirlpool/Roper
    Last Post: October 9th, 2008, 09:19 AM
  2. Whirlpool SF395LEEQ 0 - Oven not lighting (photo)
    By newdy22 in forum Whirlpool/Roper
    Last Post: April 30th, 2008, 12:33 AM
  3. Whirlpool super capacity 465 gas oven not lighting
  4. Whirlpool GLP84800 Oven light not working
    By ysp in forum Whirlpool/Roper
    Last Post: January 31st, 2007, 05:39 AM
  5. Whirlpool range oven light not working
    Last Post: January 30th, 2007, 10:15 AM
