Results 1 to 6 of 6
Thread: Whirlpool Super Capacity 465 oven stuck in self cleaning mode
    dinger15 is offline Member
    Jul 2011
    Royal Oak, MI
    Default Whirlpool Super Capacity 465 oven stuck in self cleaning mode
    Model Number: SF385PEEZ0
    Age: More than 10 years
    Tried to initiate a cleaning cycle and noticed the door didn't lock. Then tried to cancel the cycle. The display shows the "lock'd" indication below the clock and "LOC" in red in the upper right of the display. At this point I am not able to start the oven or broiler. I removed the panels on the back to expose the door lock solenoid to see if it was energized and it is not. I tried unplugging the unit for several hours only to have it remain in the same state. Control board? What do you think?
    Ok, look again at your door lock assembly and see if you notice the little switch button is pushed in or not with the little metal lever.
    If pushed-in then raise the metal lever and see if the "LOC" goes off.
    Unplug your range first before checking that. Then once you raise the metal lever plug it in, but be careful not to touching anything.
    Jul 2011
    Royal Oak, MI
    The switch is not made. I checked it with a VOM and it is functioning normally; closing when depressed and opening on release. I had the range unplugged over night and when I plugged it in the "lock'd" indicator returned along with "PF" in the upper left of the display. I depressed the clock button to reset the PF and LOC returned.
    Ok, then the problem is your clock oven control board.
    Here's the clock oven control board for your model you can order here:
    Manufacturer's Number: 6610279
    Jul 2011
    Royal Oak, MI
    Had to look up and order Almond equiv., no problem there. Thanks for the help.
  1. whirlpool self cleaning oven super capacity 465 ISSUE
    By cook1116 in forum Whirlpool/Roper
    Last Post: January 22nd, 2011, 11:32 AM
  2. Whirlpool Super Capacity 465 Gas Oven failure
    By IanW in forum Whirlpool/Roper
    Last Post: December 16th, 2010, 11:16 AM
  3. Whirlpool Super Capacity 465 / Gas Oven
    By jeff_465 in forum Whirlpool/Roper
    Last Post: November 25th, 2007, 01:26 AM
  4. Whirlpool super capacity 465 gas oven not lighting
  5. Whirlpool Super Capacity 465 Gas Oven not working
    By whirlmamma in forum Whirlpool/Roper
    Last Post: November 9th, 2005, 06:07 PM
