Old September 3rd, 2007, 12:20 PM
lpearso is on a distinguished road
Default Quiet Partner II stuck on "Lock"
I have a Whirlpool Quiet Partner II model # DU1145XTPQ1 Serial #FR4404377.
It's about 1 and a half years old. It has been working well except that every once in a while another family member will not close the door tightly enough so the washer doesn't start when the button is pushed. All I have done is to push it closed firmly.
About a week or two ago I noticed that there was about half an inch of water that hadn't drained out, but that problem went away during the next cycle.
A couple of days ago, I noticed that another family member had added detergent and thought they had turned the washer on, but nothing had happened. I closed the door more tightly and hit the start button but that didn't help. Then I fiddled with the control buttons (sorry, I don't remember the order) thinking something was hung up. That didn't work.
What I ended up with was a "lock" light that I can't turn off. I searched this sight and based on some similar problems folks had written in about, I tried turning the circuit breaker off and on. I also tried to press in the "heated dry" button for 5 seconds, but that didn't make any difference. I tried pushing in the other buttons to see if they were electrically connected. Each button I pushed would cause the "lock" light to flash a few times and then return to a study green glow.
I searched the bottom of the interior comparment and discovered two pieces of glass about an inch square (probably the remains of a broken glass) and a piece of plastic wrap about two by three inches when unwadded.
Thats where things stand now. Can anyone give me some advice.
P.s. I presently searching for my warranty.
- can someone direct me to a picture of the parts exploded?
Old September 3rd, 2007, 12:47 PM
PROBLEM: CONTROL LOCK WON’T ACCEPT KEY PRESSES,
CONTROL LOCK LED ON
Control Lockout feature
accidentally turned on by
customer.
Press and hold the Air Dry key for 5 seconds
to turn off (or on) the Control Lock feature.
Intermittent short of Air
Dry key or circuit in
keypad or keypad
connection.
See Checking Keypad Operation, page 1.
That is from your TECH SHEET.....
Old September 3rd, 2007, 12:54 PM
This will be your BREAKDOWN PAGES...
Sort of sounds like you may have stuck keys on the keypad...
Old September 3rd, 2007, 01:31 PM
Pegi,
Thanks for the parts breakdown and the other tips. I just found my purchase receipt and I've had the dishwasher 2 years and 34 days.
I'll work with your tips and get back to you one way or the other.
Larry
Old September 4th, 2007, 12:59 PM
Unhappy Managed to unlock - still no luck.
Well, I finally got it out of lock mode by
holding down one of the buttons for exactly 5 seconds.
This led me back to the original problem which is that the
dishwasher will not start. I then discovered that two of the 10
buttons on the front: the "Normal" mode selection button
and the "Start" button are unresponsive.
The diagnostic mode is triggered by pressing
dry, normal, dry, normal (or something to that effect.)
so with the normal button not working, I wasn't able
to put it into diags. And with the start button not
working, well, the dishwasher won't turn on
I took the front panel off and peeled the front laminate layer
off so I could access the buttons
(the blister style kind like on a cell phone or old calculator keyboard)
I then identified the conductive traces leading out of the
"blister sheet" into a ribbon cable that connects to the "brain"
of the dishwasher, and tested for continuity when the "buttons"
were pressed by holding the probes on a multimeter to the respective
traces on the cable.
No luck. As the offending "buttons" were pressed, the meter spiked, indicating (I think) continuity.
I also checked the thermal fuse for continuity. It was good as well.
At this point, It would seem to me that the next step to take would be
to start checking the resitances of various components as per the
tech sheet, but that's a technique that I've never had much luck with
(In cars and other appliances that is), and I was hoping that you
guys might have some clues or other low hanging fruit to pull at first.
The tech sheet is very helpful and I think I could probably fix this
thing if I could just get it into diagnostic mode.
I can post pics if that would help.
Larry.
Old September 7th, 2007, 10:40 AM
Its sounds like your control panel keypad assembly or control board is bad.
You can order both and return the one you don't need for a full refund.
Here's the control panel for your model:
Part#3385738
Here's the control board:
Part#8564546
Old September 15th, 2007, 04:48 PM
Default Dishwasher is fixed!
We ordered the two parts in question last Sunday night and they arrived Tuesday morning. As it turned out, the faulty part was the control box. We'll send the other one back. Thank you all for the sage advice and diagrams.
Larry
Old September 17th, 2007, 08:39 PM
Good job fixing it Larry, glad its back to normal again.
Quiet Partner DU915PWK does not complete cycle ga_freckles Whirlpool 8 August 3rd, 2007 09:04 AM
Whirlpool Quiet Partner II Dishwasher Not Draining Water Out cheryldaniels Whirlpool 3 May 24th, 2007 10:38 PM
Whirlpool Quiet Partner II floor drying srmulvihill Whirlpool 0 April 18th, 2007 01:43 PM
Quiet Partner III leaving soap in dispenser theschaeffer7 Whirlpool 5 November 28th, 2006 08:55 PM
Please HELP! - Quiet Partner 1 - Door latch sticking open Tim M. Whirlpool 3 November 13th, 2006 04:42 PM
