Hello,
This may be similar to thread Quiet Partner III Control panel issues We have a Quiet Partner IV that is 6.5 yrs old, model number GU1500XTKS0. Most of the buttons on the control panel are unresponsive, but "cancel" seems to still work OK. When pressing "normal" it lights up as well as "refill rinse aid" and then "sensing/soaking" joins in after the other two first light up. Same thing happens when the "quick wash" button is pressed. The lights then blink in unison. Every once and a while only the "sensing/soaking" just lights up, but then all three begin to flash again in unison. Pressing "cancel" stops the lights from flashing. I left it open last night and closed it this morning and pressed "normal" and it worked for about 10 minutes, then stopped with "73" flashing on the display (it started with 81 minutes). Also, if I hold the "cancel" button or hit it repeatedly a "2" will flash on the display. Will a new control panel resolve our issues? Thanks, Bob |
Hi Bob,
Yes a new control panel should fix it all. ![]() What color is your dishwasher control panel? white, black? Here's the white control panel for your model: Manufacturer's Number: 8269465 Here's the black one: Manufacturer's Number: 8269464 Jake
Thanks Jake, that was fast.
We will need to get the black one. Does it come with instruction manual or is there a repair manual online we can reference? Bob |
Sounds good Bob, Here is an online manual to help you change that control panel: https://secured.whirlpool.com/Servic...LE/8178022.pdf Jake
Thanks Jake.
There is a control board behind the control panel. It does not appear that this comes with control panel part # 8269464. Is there a possibility that the control board is bad? Or is it pretty definite that the control panel is the culprit based on the symptoms we see? Thanks again, Bob |
Its pretty definite its just the control panel.
You can always the control board just to be on the safe side, and if you don't need it, you can return it within 30 days for a full refund. Here's the control board for your model: Manufacturer's Number: 8564542 Jake
Thanks Jake.
I just ordered the control panel. Hopefully that does the trick. Bob |
Sounds good Bob, let us know the outcome.
Got the control panel already, very quick. But...exact same symptoms. So, unfortunately it does not appear to be the control panel. I will need to return the control panel. Is it clear how to do that on the appliance pros website? So, as to the problem...will the control board fix it or is there some other problem? Is there some sensor or switch that can be bad and cause the dishwasher to act the way it is? Bob |
| Maytag Quiet series 300 Control panel | superbond | Maytag/Magic Chef/Admiral/Jenn-Air | 2 | March 11th, 2008 12:45 PM |
| Amana ARTS6650E Control Panel Issues | Blarg | Amana | 3 | December 3rd, 2007 12:08 PM |
| Quiet Partner III Control panel issues | Markb | Whirlpool | 9 | November 30th, 2007 11:53 PM |
| Neptune control panel issues | brianl | Maytag/Magic Chef/Admiral/Jenn-Air | 5 | November 4th, 2007 11:13 PM |
| Whirlpool Quiet Partner II DUL200PKQ1 - adjustable top rack | oneder | Whirlpool | 0 | January 16th, 2007 07:57 AM |
