Old June 4th, 2008, 01:29 PM
Chris41 is on a distinguished road
Default Whirlpool GRR448LXPB0
After power is applied the display cycles through numbers 84, 85,& 86 in red and displays a lower case r followed by the number 4 in blue. None of the keypads have any affect other thant the r 4 going out when the button/keypad is held. This happened after a thunderstorm which also took out my router and cable modem. I have a bad feeling that it's the main control board. I couldn't find any error codes that match. Your help is always appreciated.
Old June 4th, 2008, 01:43 PM
I'm having a hard time with that model number. Could you double check it for me.
Old June 4th, 2008, 03:38 PM
Default Whirlpool Model GR448LXPB0
Sorry about that first post with an extra R in the model number.
Old June 4th, 2008, 06:39 PM
I just got done reading the tech sheet on that model and your feeling was right. It looks like you'll need a new control, Part# 9757271. Sounds like that was an expensive bolt of lightning.
Old June 6th, 2008, 11:21 AM
Default What else could it be?
Just got the part installed and I get the same symptoms.
Old June 6th, 2008, 12:59 PM
Then the only other part it could be is the control panel membrane assembly.
Here's the cheapest one I found for your model:
Manufacturer's Number: 9758473
icon
Whirlpool Duet is a Nightmare! CheerMom Whirlpool Brands Forum 2 November 3rd, 2008 09:45 AM
Whirlpool du1148xtpqa dishwasher sensing won't work dmello1284 Whirlpool 21 August 22nd, 2007 09:49 AM
Whirlpool WED9400S Drum Light nanook Whirlpool/KitchenAid 0 July 28th, 2007 05:55 PM
Done with Whirlpool & Kenmore Beyond Lemons automan1223 Sears Kenmore Brand Forum 0 March 3rd, 2007 10:57 AM
Kitchenaid vs Whirlpool? rv8 KitchenAid 1 January 25th, 2006 11:22 PM
