Old June 25th, 2008, 12:11 PM
THier is on a distinguished road
Default Another Whirlpool 365
I tried a search and couldn't find an answer,,
I have a WP 365
Model SF370LEGN
Ser. RJ1212113
Oven not working, the glow bar glows fine but it seems no gas.
Display, good, temp and warmup countdown, good
Stove top good
Broiler good
I looked at the "direct ignition" manual,, but mine has glow bar.
I have multimeters ect so any diagnostic help would be appr.
Tom
Old June 25th, 2008, 12:42 PM
Look on the oven safety valve for an amp value. Use a clamp type amp meter around one of the ignitor wires. It needs to pull that many amps to open the safety valve. I'm not sure but I think it's like 3.1 to 3.3 amps. Anything less, replace the ignitor.
Old June 25th, 2008, 05:39 PM
Hmmm,, couldn't find value on safety valve,, but found this in manual-----
Lower ignitor resistance increases the current flow through the bimetal coil. When the ignitor is fully
heated, its resistance is low. Low resistance causes maximum current to flow through the bimetal
coil (2.5 to 3.6 amps).-----
Mine peaked at 1.68a,,, (even though it glows bright orange) guessing thats the issue huh?
Going to order the ignitor.
Tom
Old June 25th, 2008, 05:45 PM
Yep, Replacing the ignitor should fix the problem.
Old June 25th, 2008, 06:24 PM
Can I swap the Broiler to the oven untill the ignitor gets here? Wife uses the oven very often,, broiler rarely.
Tom
Old June 25th, 2008, 07:39 PM
Yes, there shouldn't be any problems. They are the same ignitor.
The Following User Says Thank You to redbeardnmt For This Useful Post:
THier (July 20th, 2008)
Old June 25th, 2008, 11:51 PM
Here's the oven/broiler igniter for your model, in case you ever need to order it:
Manufacturer's Number: 4342528
Old June 27th, 2008, 06:59 PM
Igniter came today,, problem solved!! Thanks for the great site and help!!
Tom
Old June 28th, 2008, 12:28 AM
Excellent, good job Tom fixing it.
Old June 28th, 2008, 04:23 AM
The credit goes to redbeardmt, I figured if the igniter was glowing as bright as it was that it would be good. But i doubted the valve was the problem as the broiler worked.
Tom
Whirlpool Duet is a Nightmare! CheerMom Whirlpool Brands Forum 2 November 3rd, 2008 11:45 AM
Whirlpool du1148xtpqa dishwasher sensing won't work dmello1284 Whirlpool 21 August 22nd, 2007 11:49 AM
Whirlpool WED9400S Drum Light nanook Whirlpool/KitchenAid 0 July 28th, 2007 07:55 PM
Done with Whirlpool & Kenmore Beyond Lemons automan1223 Sears Kenmore Brand Forum 0 March 3rd, 2007 12:57 PM
Kitchenaid vs Whirlpool? rv8 KitchenAid 1 January 26th, 2006 01:22 AM
